2.4 sump screen options
I have both the old original sump screen and the one for an sc.. Which should I use or does it even matter?
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 11-02-2017, 04:03 AM
screen
The one on the left is the latest update and the preffered style, it improves the scavenging like the 3.2 and later style pumps have
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 11-02-2017, 04:46 AM
Thank you that is what I thought but wanted confirmation. My pump has been improved by supertec so wanted to make sure the screen is preferred.
Ben
89 944,85.5 944
914-6werkshop.com
Old 11-02-2017, 04:57 AM
I think if your case has the oil bypass and if you are using a 4 rib pump or later, the venturi style sump screen (on the left) is the right one to use,
Tom Butler
1973 RSR Clone
1970 911E
914-6 GT Recreation in Process
Old 11-03-2017, 04:33 AM
Yes oil bypass has been done and here is the picture of the pump after upgrade from supertec.
Ben
89 944,85.5 944
914-6werkshop.com
Old 11-03-2017, 06:41 AM
