Chain fence eating turbo
ARP rod bolt stretch DIMENSION for a 3.2
Can't find my datasheet for my 3.2 for the proper rod bolt stretch.
Rods are hung, ready for bolt stretch.
Anyone know?
TIA!!!!
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 11-17-2017, 07:29 AM
Registered Minimalist
75 911s's Avatar
Check this thread
from the thread "As all that I was checking was the required torque to get the .0100 - .0105 stretch"
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 11-17-2017, 08:09 AM
75 911s's Avatar
Obviously check with ARP and the part number etc. I guess you can torque if you don't have the stretch gauge
Old 11-17-2017, 08:15 AM
Thank you Duane!
Old 11-17-2017, 08:57 AM
BURN-BROS's Avatar
That stretch spec is for 10mm bolts. You should have 9mm no?
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 11-17-2017, 09:36 AM
Yes, the 3.2 should be 9mm. Here is the correct doc for the 9mm bolts:
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 11-17-2017, 11:16 AM
That's what I remember. Thank you!!!!!
Old 11-17-2017, 11:51 AM
I went .01025 to split the difference accounting for error.
Old 11-17-2017, 01:45 PM
Under the radar
Trackrash's Avatar
What are you using to measure to .00005"?
Gordon
'71 911 Coupe 3,0L outlawed
Old 11-18-2017, 05:07 PM
My eyeball.
Quarter of the way between 0.010" hash mark and the hash mark after.
Old 11-18-2017, 05:34 PM
