2.2L vs 2.4L head towers
I am putting together a 2.2L engine. Is the towers for 2.2L heads the same as the towers for 2.4L heads? Can I use 2.4L heads on a 84mm pistons (2.2L) - I'm assuming they're the same size but different crankshaft sizes.
thanks |
Yes 2.2 cam towers and 2.4 cam towers are the same as far as fitting your heads. And your 2.4 heads or 2.2 heads will fit the 84mm P&L's.
Mark Jung Bend, OR MFI Werks.com |
