Oil bypass - quick question
Guys, my mag case just came back from the machine shop and I am doing final prepping before closing the case. What is the recommendation to hold the new brass plug inside in place? loctite blue? red?
Old 01-10-2018, 01:48 AM
Use red, you’re never going to remove it again.
Bruce
Old 01-10-2018, 07:17 PM
totle's Avatar
Planning on doing the same in my 2.2 case, including installing piston squirters
What oil pump is minimum when doing this mods?
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 01-11-2018, 02:30 PM
I'm going by Wayne's book and have the 4-rib pump. Mine is a '73 case so it already has the squirters - which I am currently trying to unblock (waiting for my seafoam to arrive).....engine gets all the suggested upgrades - pressure-fed tensioners, turbo covers, RSR sealing rings, updated idler arms, ARP bolts.
Old 01-12-2018, 05:13 AM
