Oil pump small nuts... Loctite?
Checked and reassembled my oil pump. The 4 small nuts holding it together didn't seem to have any loctite on there from the factory...
Figured it couldn't hurt... You guys use the blue? Red? None? Thanks, and merry Christmas! |
loctite
I have never seen Loctite used from the factory.The pump is well secured at 3 points so probably not much movement for load happening.Ciao Fred
The three nuts that hold the pump to the case have the safety clips... I am thinking about the 4 tiny nuts that hold the oil pump itself together. The nuts are really odd, with some kind of capture washer that encompasses the nut... When I took my pump apart, those didn't seem too tight, and didn't seem to have Loctite on there... May just use red Loctite to be sure they don't come off... its just that the pass through bolts are fairly thin. Don't want to snap one off due to red Loctite if I ever have to take this thing apart again... |
If you're worried use the Red Loctite. It can always be nullified with heat.
Under the radar
I don't think it would be a bad idea to use loctite on those nuts. I used blue loctite on mine.
BTW, a friend of mine had to rebuild his motor after those nuts came loose on his SC motor.....
When they're first put to together with new bolts at the factory I feel confident in them assembled with no loctite, or however they did it.
With older used pumps and bolts I'd feel better with a little loctite on the pump housing bolts. You know they won't come loose. |
Trackrash said all you need to know . Use red loctite . The nuts do not seem very tight on original pumps I have disassembled . I use red loctite . I think tightening the nuts too tight will distort the pump . I like 60 in/lbs .
I am Trackrashe's friend that had the nuts loosen on my SC pump. I bought a brand new, later pump. I removed the 4 nuts and red Loctited them!
Andy Brian |
Under the radar
Andy, lets see a shot of your new motor! It's going to be a rocket.
Hey Gordon! Let me get a shot of it today. I am doing the cam timing.
Andy Brian |
AircooledB4itwascool
Hey Bo,
Sorry to infringe on your thread. Tried to private message you back and it states your in box is full and you need to clear out some of your inbox. Thanks, Frank
www.perfectpowerinc.com www.williamknightperformance.com |
