Chain fence eating turbo
Originally Posted by Matt Monson View Post
9meister makes all new heads out of billet like CMW does.
History of CMW Billet Heads
Minus the ports, making billet heads for a 911 would be so simple. If you had a 5-axis mill lying around, then it would be simple.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 01-18-2018, 09:12 AM
gearhead
Mine is for sale.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 01-18-2018, 09:51 AM
WP0ZZZ's Avatar
Originally Posted by LeftCoastErik View Post
I have full EFI timing control with the stock 3.6 dizzy
Would you mind elaborating on this? It's not clear to me whether the ignition timing is controlled mechanically by the distributor.
Old 01-18-2018, 10:59 AM
Mine is for sale.
I don't have the money for those gems (unless you barter...), but would love to hear the specs like valve sizes, port sizes, and CFM @ given lift...
Old 01-18-2018, 11:03 AM
Under the radar
Trackrash's Avatar
Mine is for sale.
Your MILL is for sale? Details please.
Gordon
'71 911 Coupe 3,0L outlawed
Old 01-18-2018, 03:23 PM
I would rather be driving
jpnovak's Avatar
It is easy to control timing through a distributor. The process goes something like this.
-Crank sensor timing wheel sends pulse signal to ECU indicating crank angle.
-ECU interprets crank angle changes and calculates engine speeed.
-ECU is programmed to send a spark ignite signal at specific crank angles that are programmed. For example a 6 cylinder would fire every 120 deg. ECU calculates timing dwell and offset according to ignition map, engine conditions and correction factors.
-Spark ignite signal is picked up by (choose one: ignitor, MSD, CDI, etc) and sends spark pulse through distributor.
Distributor remains to phase spark to correct cylinder. internal mechanical advance may be retained for rotor phasing.
I do this often on early cars with EFI. Modern electronic control with vintage aesthetics.
Old 01-18-2018, 03:42 PM
WP0ZZZ's Avatar
Thanks very much for taking the time to answer!
Old 01-18-2018, 04:46 PM
flyn-hawn's Avatar
50 PMO ITB with AEM Infinity ecu, 328hp at the wheel
Follow me on instagram, @flyin.hawaiin
www.davekealoha.com
Old 02-21-2018, 10:13 PM
Send a message via AIM to blockhed
What's inside that engine to create 328rwhp?
Old 02-22-2018, 04:12 AM
safe's Avatar
How did you fit an early fan to a 964 engine, are they compatible?
Magnus
Old 02-22-2018, 04:48 AM
flyn-hawn's Avatar
lots of $$$$
I first saw "rswannabe" with the setup, but it does just bolt on. You need to cut out a couple slots in the bottom of the strap. We also used a 3.6 shroud and cut it as it comes up to the fan and mated a 3.2 upper to it.
www.davekealoha.com
Old 02-22-2018, 05:54 AM
Sick!!!
Old 02-22-2018, 06:19 AM
Originally Posted by flyn-hawn View Post
lots of $$$$
Yeah I figured that was obvious was looking for more details on combo
Old 02-22-2018, 08:09 AM
flyn-hawn's Avatar
3.8 Mahle motorsport p&c 11:5.1
Pauter rods
WebCam late 3.8 rsr cams
Aasco springs & ti retainers
some minimal porting
pmo 50 itb
b&b 1.75 exhaust
jb twin plug distributor
aem infinity ecu
I think that covers the basics
www.davekealoha.com
Old 02-22-2018, 08:43 AM
safe's Avatar
Pauter rods
pmo 50 itb
b&b 1.75 exhaust
aem infinity ecu
With a 915 gearbox? Done anything special with that?
I'm trying to get a friend to install his 3.8 rsr (370ish fwhp) into his, now engineless, RS 73 tribute.
Magnus
Old 02-22-2018, 09:41 AM
flyn-hawn's Avatar
G50 axles, and output shafts, WEVO side cover and internal bearing retainer. LSD, Patrick lightweight flywheel and centerforce clutch
www.davekealoha.com
Old 02-22-2018, 10:09 AM
