Irrationally exuberant
ChrisBennet's Avatar
KTL's tips are spot on: Here are few more:
  1. Clean the case perimeter holes to remove old Loctite. Otherwise old hardened Loctite "crumbs" inside the holes can break off and fall on the sealing surface when you assemble the case.
  2. If you use reusable rod bolts (like ARP), the machinist will need them when machining the rods. (They distort the rod end differently than the stock bolts.)
  3. Call me a heathen, but I never replace the distributor O-ring. I've never seen a leak there and using a new O-ring only makes it a pain to get the distributor in.
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-15-2018, 09:13 AM
Targa_PB_78_SC
mike sampsel's Avatar
Originally Posted by Drbraunsr View Post
Mark the tightening sequence of the case thru-bolts on the case with a Sharpie ( it wipes off easy with a little laquer thinner).
Buy (and use) Stomski's circlip injector tool. It's patented for a reason. I couldn't imagine installing the circlips without it.
Bingo on this sharpie idea! Gonna do it for my case redo! Thanks and I’ve borrowed the stomski clip installer.
Old 08-05-2019, 04:19 PM
