911 T & S Head Volume Question
I have a set of 73.5 T CIS heads that I want to convert to 73 S specs to run with PMO carbs.
My limited research indicates that: T Valves are 46mm Intake/40mm Exhaust T Ports are 30mm Intake/33mm Exhaust S Valves are 46mm Intake/40mm Exhaust S Ports are 36mm Intake/35mm Exhaust I would obviously need the T heads ported to S specs and have the CIS port blocked. I will be running stock OE Mahle 2.4 S pistons (84P11+ (oversize group 1)) with a stock 73/74 2.4 crank and rods. Is the volume of the combustion chamber the same between the T and S heads? Thanks for your help. Greg Last edited by grotvik; 02-08-2018 at 09:38 AM.. |
Hi Greg,
Basic chamber volumes are the same between all of the 2.2-2.4 heads. 2.7 ones are slightly larger. I would strongly recommend measuring yours so you know precisely what your CR will be as thats important with today's gasolines. Its possible to have your heads CNC'ed to match "S" heads, but its not cheap to do. Plugging the CIS injector holes is easy.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Hi Steve,
Thanks for the feedback. I'm a newbie to this so it's nice to get professional feedback. I'd hate to go down this road and have someone tell me it can't be done. I will call you sometime and discuss my options. Greg |
gearhead
Send them to Steve. I've got the exact same heads and very similar plans. He's getting mine next week.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Hi Matt. What cams are you going to use? E, S, combo E/S, other?
gearhead
After talking to Steve yesterday I think I’ve settled on Mod S versus Mod solex. My engine is a little different because it’s going to be a 2.5 short stroke. But the heads will be near identical to yours.
Thanks for the info, Matt. It's greatly appreciated. I bought my small spigot 7R case from Tom Butler and he suggested going the 2.5 route also but then I found the 2.4 S pistons which may change my direction a bit. He suggested a grind somewhere between E and S. Not sure if that's still applicable. Your short stroke 2.5 will be a hoot to drive.
Thanks again, Greg |
Under the radar
Single plug or twin?
Keith - Calgary 1969 912R (911 engine) - Blutorange |
gearhead
Yes.
I’m having Steve prep the heads and lower covers for it. But on the first passby I will set it up single plug. I am undecided on injection versus carbs. So I bought both and will try them both out. I’ve built a couple dozen Subaru engines but I’ve never done a 911 one. I am intending for this to be a fun process. My car is my toy.
I would rather be driving
73.5 CIS heads easily accept EFI injectors. Get the long tip DEKA common BMW 3-, and 5- series applications. They will fit nicely into the intake port. Then run MFI stacks for an ITB EFI setup.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
gearhead
Not interested. I'm building a period correct look into my car.
