2.7 camshaft selection
I recently increased my 1973 2.4l to 2.7l with non-rs pistons etc. I have a set of early Solex 109-110 cams which have too much overlap to run with C.I.S. Any suggestions on cam selection for this combo. Also, I have a set of 16x6 Fuchs for the front of my 911 & 16x7 for the rear. What's the biggest tire I can run on the rear without any clearance problems. Any input is appreciated. Thanks, Craig.
Old 02-10-2018, 09:45 AM
As long as you are using standard CIS pistons, your choice is CIS 2.7 cams. Not having done it, installing 3.0/3.2 cams should work too but you ll need cam carriers to go with the later cams.
Bruce
Old 02-10-2018, 02:36 PM
I Once had a 2.7 with CIS stock pistons with a 964 grind. Seem to pull hard. I ran it with carbs and port and polished heads.
Old 02-10-2018, 03:30 PM
Under the radar
Trackrash's Avatar
I don't know why you couldn't get your cams reground to something equivalent to what the SCs and Carreras had.
In the rear I know that some have shoehorned 225s on the rear. Those might rub, depending on your alignment settings, ride height, actual tire size, and bead rolling however.
Gordon
'71 911 Coupe 3,0L outlawed
Old 02-10-2018, 05:11 PM
E Sully's Avatar
You can consider the 2.7 CIS 'S' camshafts. I picked up a set to use in my 2.4 CIS rebuild.
Ed
1973.5 T
Old 02-11-2018, 06:03 AM
JmuRiz's Avatar
I bought a set of SC-grind cams (3 lobe)for 2.7 CIS pistons for my rebuild, but had to get new pistons when my build went from a cam-swap to a full on rebuild.
PM me if interested, they are good cams, just couldn't use them anymore.
Or if you'd like a 2nd set to send out for regrind, I have a set of stock '77 2.7 cams too.
'73 2.0 914 (2.8 /6 conversion in progress)
'64 356SC
'65 Ducati Falcon 80
‘19 Audi SQ5
Old 02-12-2018, 06:58 AM
