Chain fence eating turbo
Will the JE 98mm piston rings work with Max Moritz pistons?
As the title says, I see Pelican offers 98mm JE piston rings for cheaper than I paid for TotalSeal conventional rings for my FLATTOP Max Moritz pistons.
Will these work? I assume yes, but wanted to confirm. PN: JE-612U6-3858 Wanted to order soon, or I would have measured everything to confirm. TIA
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel Last edited by Tippy; 01-06-2017 at 08:36 AM.. |
I think you will have to machine the pistons unless they already use the same size rings,
Max Moritz 98mm pistons which I had in the past used a ring pack which is 1.2 x 1.2 x 3.0mm and it is difficult to find rings to suit. The Mahle Motorsport version of this piston uses a 1.0 x 1. x 2.0 mm ring pack. I think JE use NPR Rings which are good. |
Bummer.
JE shows 1.5 X 1.5 X 3.0 |
What compression ratio?
Any Boost?
Kuehl 1987 911 cab, modified https://griffiths.com/ |
I don't have flat tops, but I was cracking rings on my 100mm with rings that came with my JE 9.5:1,
single plug hemi head location and 8 psi boost don't help, lol. I had Total Seal figure out what I needed, they were worth every penny and the tech support was great.
Yeah, I'll have to go TotalSeal again, then.
I would measure the piston just to sure of the ring sizes.
I would, but my engine is together right now.
I have a most complete set low mileage Mahle, I think there was one broken in the set.
I had to buy a full set of totalseal for the one broken OE Bruce |
Reviving an old thread since I'm currently doing a top-end rebuild on my 3.2 Max Moritz conversion.
I'm at the least page of the internet, and found nothing yet?! Did you guys find the piston rings anywhere or do I order from Total Seal? Thanks! |
Schleprock
Nux,
I would give EBS Racing a call. They will be able to give you the scoop on the rings for your pistons.
Kevin L '86 Carrera "Larry" |
I only started the thread because I saw the JE rings are much cheaper than my custom TotalSeal's I got from EBS.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
First thing in the morning then - thanks!
