2.2T head rebuild - new springs?
Question for the knowledgeable. I'll be getting the heads rebuilt on my 2.2T soon. I will be doing new valves, guides, and of course seals. What's the consensus of springs? Is it needed? Do these fail often?
For reference, it's a stock rebuild of a 125hp 2.2T from 1971.
Instagram = glen.cordle for my Porsche artwork and 3D models. |
Slippery Slope Expert
How many miles? Personally I would change them. Relatively cheap insurance. Catastrophic if they fail.
“As new technologies become indistinguishable from magic, and I can no longer tinker, the magic goes away for me.” |
Chain fence eating turbo
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
Unknown miles on the engine, if bearing surfaces are any indication it's led a pretty leisurely life.
I'll look into getting the springs tested against the spec. Looking at our forum sponsors catalog, it's about $171 for the cheapies (O.E.M. brand, which I've never been fond of) and $500-$600 for Porsche or "high performance" aasco springs. I'm just a 914 guy, so those numbers don't fall into the relatively cheap category.
The title has something like 964 parts in it.
Under the radar
Check out Eibach. They have quality 911 sets for around $75.
Thanks Gordon, any idea where I can purchase them online? I see them in their catalog but can't find anywhere to buy them.
Edit: found them a couple places and they're up around the $300 mark.
Instagram = glen.cordle for my Porsche artwork and 3D models. Last edited by Optimusglen; 02-14-2018 at 06:32 PM.. |
gearhead
I'm building a 7500rpm twin plus short stroke 2.5l engine on 73.5 CIS heads. Steve Weiner is prepping them. He's going to test the springs and only replace as needed.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Under the radar
https://www.summitracing.com/search?SortBy=BestKeywordMatch&SortOrder=Ascending&keyword=911%20valve%20springs
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 02-14-2018 at 07:18 PM.. |
abit off center
Porsche stock springs are very good if in spec and most are out of the thousands I have serviced. But spec is not everything, look for pitting on the spring, that will cause a failure in the future.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. Last edited by cgarr; 02-14-2018 at 08:47 PM.. |
The only time I use aftermarket springs are in race (or track) engines that will see continuous use in excess of 7K RPM.
Its very important to choose such springs wisely since many of them are far too stiff and this puts heavy wear (not to mention drag) on cams, rocker arms, rocker shafts, chain sprockets, idlers, and IS sprockets. In short, you pay a penalty for short component life if you make a mistake. Cheaper isn't always better.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Thanks for posting this, I ended up buying these from him.
Great price
