Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Stomski circlip tool
I have seen the light! Based on the advice of the knowledgeable people on this forum, I ordered the tool and received it in two days - super service.
I can say for the likes of JE and Carrillo heavy wire circlips, it is flat out the best tool money you will ever spend. What was once a job high in frustration and possible personal injury turns into: click, click done. Thanks to Steven Stomski for making such a fine tool available.
1986 Targa Guards Red
2021 MT09 SP
Old 02-14-2018, 04:13 AM
+1000
Old 02-14-2018, 08:09 AM
You should try his valve adjustment dial gauge unit..excellent as is everything I have of his products..
Bruce
Old 02-14-2018, 10:30 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by brighton911 View Post
... I ordered the tool and received it in two days - super service...
I'll take it...
Who Will Live... Will See
Old 02-14-2018, 04:07 PM
Jeff Alton's Avatar
We use that tool on every aircooled motor we build. No more screwdriver through the palm or you hand... search and you will see I speak from experience....
www.turn3autosport.com
Old 02-14-2018, 07:50 PM
Slippery Slope Expert
Steam Driver's Avatar
Stomski tools are great and as has been said, service is immediate. The cam sprocket holder/bolt tool is wonderful. Pricey and perhaps “gilding the lily” as opposed to the factory tool but it makes holding cam timing while tightening the bolt, et al, much easier. Eliminates the need for that third hand.
“As new technologies become indistinguishable from magic, and I can no longer tinker, the magic goes away for me.”
Old 02-15-2018, 04:19 AM
Straight shooter
Lapkritis's Avatar
If you're in a pinch and can't wait for the tool then copper tubing and a 5/8" socket from home Depot, Lowe's or any neighborhood hardware store like ace works the same.
Sent from my SM-T580 using Tapatalk
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 02-26-2018, 11:27 AM
I tried the 3/4 copper pipe swagged to thin the wall out and so it fit the 23 mm opening of the piston. With the heavy wire of the JE and Carrillo clips, I found that using the pipe permanently deformed the circlip. The Stomski tool has a very thin wall thickness that does not deform the circlip at all - I verified that.
2021 MT09 SP
Old 02-26-2018, 04:34 PM
Straight shooter
Lapkritis's Avatar
Sounds like the copper wasn't thinned enough. Worked great for me.
Old 02-27-2018, 12:46 PM
Under the radar
Trackrash's Avatar
For my SC build I used EMT tubing. Thin walled tubing, worked great with a machined down bolt as a guide.
Gordon
'71 911 Coupe 3,0L outlawed
Old 02-28-2018, 10:27 AM
I used the Stomski tool for the circlip installation - done in about 20 mins - the tool works as advertised! Can't imagine doing that task without it.
Old 03-11-2018, 07:55 PM
Still here
pmax's Avatar
Yes, the Stomski is one fine tool but in what ways is it better than the homemade contraptions with a tube and an old socket ?
Here's another example Making A Piston Clip Tool (Guerilla Method)
Old 03-11-2018, 10:35 PM
Just experienced the circlip installation onto JE pistons. That circlip is one stout beast.
I can't imagine success without the Stomski tool. "Must Have" tool for any Porsche toolbox.
Old 03-24-2018, 02:22 PM
My Stomski knock-offs. I think they cost me about $20, plus the 10k or so in lathe, welders, etc etc. But hey, I saved money by making them myself.
Old 03-24-2018, 05:47 PM
There might be a market for those home made tools..character.
Old 03-25-2018, 07:46 AM
Only if I want to work for close to nothing. Maybe the chain tensioners, they are very simple but do the job and easy to make. But then again unless you are doing this a lot just use a clamp..
Old 03-25-2018, 11:35 AM
shbop's Avatar
There's a lot of ways to 'skin a cat', but if you're a tool guy; it's hard to beat Stomski's stuff. Beautiful & fun to use.
Jon
Old 03-25-2018, 07:43 PM
Ken911's Avatar
so which one for JE turbo pistons with the heavy wire clips the 22 or the 23?
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 03-27-2018, 02:39 AM
You have 88 turbo. Use 23mm.
Bruce
Old 03-27-2018, 02:58 AM
Ken911's Avatar
ok thanks
2019 Silverado 6.2L
Old 03-27-2018, 03:11 AM
