2nd oil cooler
I know I've seen this before but now I can't find it. 3.0l twin plug in 72 911. I have the oil cooler in the right front fender but air flow is a problem. I thought when I moved to Oregon oil temp wouldn't be a problem but on a 70 deg day I still have oil temps of 230 on a 20 minute session DE.
So should I add a second oil cooler in the left fender or go for the center mounted cooler?
Kent Olsen 72 911 SCT upgraded 3.0L McMinnville, Ore |
I have a center mount in a '73 with a 3 liter twin plug. Oil temp never goes over 200 deg F.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
It's a 914 ...
Some guys take the headlight out on the side of the oil cooler (passenger side I believe?) and cut a hole in the back of the headlight bucket to allow some direct air flow to the cooler. Of course, a center mount cooler is the best option for cooling ...
Try not, Do or Do not
We've added a second cooler to the left front fender which minimizes the modifications to the chassis of the car. Preserving these old cars is important to so many owners.
We even built a retro-fit cooler for 914/6 that allows for a remote cooler without modifying anything but the engine lid. ![]() ![]()
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Henry
Where did you find to kit for the left cooler. I couldn't find it on our host's site.
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452) 911E Coupe -70 Carrera 3,2 -84 Sold |
911 Oil cooling
Kent,
If you have space to add an electric fan that would be my first suggestion - - that is of course if you have the Carrera fender cooler and not the trombone. The other option is to get more outside air flow to the existing oil cooler. this usually means ducting panels and maybe a new hole somewhere - - like was suggested for the headlight opening. If you only have the cooling problem at the track then cutting the back of the headlight bucket is a good option, along with some ducting panels to make sure the air flow is THRU the cooler. We went thru this with my son's race car when we swapped out the 3.2 for a 3.8 (which doesn't have an oil cooler at the engine like the 3.2) - - - we have 3 oil coolers and lots of duct panels and headlight holes - - but then it is a bit warmer here in Phoenix than most places . . . You might call and talk to Chuck Moreland at Elephant about your particular situation. Interesting: We had an Aubergine 1972 911T back in 1977 in Kentucky/Virginia - - I am color blind and thought it was Blue - until my wife told me, " You bought a Purple car !! " Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine |
Hi Kent
Which solution did you opt to go with? How did it work? Johan
Hey Johan
Surprisingly I'm in Chula Vista at the Marina RV park in my Motor Home till the end of the month. Had lunch with Mike Gagan last week. Well first I cut out the battery box. Moved battery into the smugglers box. I then fabbed in some aluminum to cover the hole and riveted it in place. Then I took that insulation stuff you spray into corners in your house and sprayed it around the sides of the cooler so the air has to go thru it. So far the only time I've had a issue is at Oregon Raceway Park in eastern Oregon. Short tight and no long straight only 4th gear on the short straight. My red line is 7200 and if I stay out of 2nd gear my oil temp stays around 220.
Glad to hear you were able to make it work with only one cooler
Hope you ave been enjoying your time in San Diego! Johan
