2r Case Stud locations
Hi,
Is there a reference available anywhere for case stud locations? Its a 1970 2.2E mag case. The machine shop removed them all to do the machining and i'm not certain where they all go back. Thanks |
Under the radar
Wayne's book has several pictures of a case being assembled. You could probably figure it out by looking at those. https://www.pelicanparts.com/catalog/accessories/rebuilding-porsche-911-engines.htm
Maybe someone who has a case laying around could post a picture.
Does this help?
Keith - Calgary 1969 912R (911 engine) - Blutorange |
Maybe this can help.
This is taken from our notes on the mag cases. There could be some minor differences. We remove all the case fasteners from the case when doing any work on the case and had this in our engine notes for this older engine. We value our information and rarely give out IP stuff, but this is something anyone measure and nothing special. Hope it helps. Porsche case stud locations and stud heights. 911 Magnesium case. 4-5-6 case half. Stud size mm Location installed height mm 8.00 3 x front 1st motion 79.0 10.00 #7 main brg 55.00 8.00 1st motion rear 108.00 8.00 perimeter 32.00 8.00 2 x oil pump rear 58.00 8.00 3 x oil pump 20.00 8.00 1 x breather mid 52.00 8.00 5 x chain hsg 22.00 1-2-3 case half 8.00 front lower 33.00 8.00 rear lower 32.00 10.00 2 x rear main 120.00 |
Our host has PDF copies of Porsche parts manuals. So does Porsche Cars North America on their website! Download the manual closest to your case model. It is full of exploded diagrams, and when you cross reference the numbered parts on the diagram with the (eventual) description of the part, usually you get both the diameter and pitch of the stud or other fastener, but also the length. Plus the drawings show which goes where.
That should compliment Neil's great listing. |
Thanks guys all very useful answers. I should be able to figure it from the above info.
