Jerry Woods Carrera Tensioner Chain Gaurds. What is proper tension for chains?
I have a 78 SC motor with new Carrera pressure fed tensioners. I bought JWs newer chain guard kit, which is a "cap" and spacers that fit on the tip of the tensioner and prevent complete collapse in case of failure. There are 12 different spacer combos I can have. I also bought his tension guard tool kit. I cannot figure out how tight is too tight. Using my fingers to hand tighten the tool I can make a large range of possible gaps between the idler arm and top of tensioner. Who has installed these before that knows the proper way to set tension?
Andy Brian
Old 04-21-2018, 02:14 PM
Sorry, I can’t be of any help with your question, but could give a link to the product? A quick search didn’t help me find it.
Rutager West
Old 04-22-2018, 02:44 AM
I found it by talking to a guy at Jerry Woods. I was calling looking for the external locking collar. This is what I bought.
Andy Brian
Old 04-22-2018, 07:32 AM
Thanks Andy,
They don’t list it on their website, so I guess I would need to call to see if it is still available.
-Rutager
Rutager West
Old 04-22-2018, 12:38 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Use the tensioner's ability to load the chain as your guide. The tensioner itself is presently loading the chain in its resting position. A common misconception is the oil feed/pressure from the running engine is what provides the chain tension. Actually the oil mostly provides a dampening of spring tension and doesn't provide all the actual load/support.
So with the tensioner installed, use the amount of play you feel in the chain as your guide for setting the tension with the tool. That's why the directions say "slightly load the chain" because JWE wants you to establish the same amount of chain tension, but only a little bit more, that is currently being applied by the tensioner.
Kevin L
'86 Carrera "Larry"
Old 04-23-2018, 02:56 PM
Under the radar
Trackrash's Avatar
Its not the tension, it is the clearance when installing the limiters in the tensioners. If your tensioner is not firm, replace it. No reason to take chances.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-23-2018, 04:36 PM
Thanks guys! I spoke with Jerry Woods today. Basically the tensioning tool is designed to act as a third hand. I used one hand and squeezed the idler arm tight with my thumb under idler arm and fingers on top of chain housing. Use your other hand and adjust the tensioning tool to to keep it tight. Some fiddling to get the feel of it, but finger tight.
Andy Brian
Old 04-23-2018, 10:49 PM
