Thermo Valve
I search a number of forums and can't get a straight answer on the placement of the thermo valve. On one site, it showed it attached to the #2 intake pipe. On another, it was attached to the blower fan support. Where does the thermo valve go? I would like to get it right. The engine is a 77 ROW 2.7l.
Thanks in advance, all.
71 911T/2.7
Old 05-07-2018, 03:30 PM
Did you see this?
1977 Porsche Thermo Valve Location
Old 05-07-2018, 04:01 PM
Administrator
Dmitry at Pelican Parts's Avatar
Hello - take a look at the link below to an earlier thread where this is discussed. Hope this helps you and best of luck!
Old 05-07-2018, 04:03 PM
Thermo valve location
So, the #2 air duct does have a spot for the support of the new fan I installed. It also has two threaded attachment points. See pictures I've attached.
71 911T/2.7
Old 05-08-2018, 02:38 PM
WUR Bosch ID number...........
JakeV,
The WUR on your engine does look like the typical WUR used in ‘76-‘77 models. Could you post the Bosch ID number on top of the WUR? It should read like 0 438 140 xxx. The last three (3) digits will identify it. Thanks.
Tony
Old 05-09-2018, 12:17 PM
WUR Part #
0 438 140 033
71 911T/2.7
Old 05-09-2018, 02:36 PM
Wur........
0 438 140 033
That is the correct WUR. I could not see the nipple for the vent line in your picture. Thanks.
Tony
Old 05-10-2018, 04:35 AM
