iamchappy's Avatar
Removing head from cylinders
I am disassembling a 78 3.0 the 4-5-6 head with a little wiggling lifted straight off with the washers, the other side 1-2-3 seems to be stuck and held on by the washers, i was able to get 4 washers on the sides free but the inner headstud washers dont want to budge, any suggestions or tricks to free up those washers so i can lift the head off.
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 05-24-2018, 12:25 PM
Copper hammer, just dont hit the fins, a few taps both sides near the manifolds bosses should free it
Old 05-24-2018, 12:47 PM
I would rather be driving
jpnovak's Avatar
I use a wood drift and deadblow hammer to knock them loose. Often the issue is 574 on the alignment pins causing them to stick.
Old 05-24-2018, 12:55 PM
The oil return tubes hold the heads to the cylinder too.
Bruce
Old 05-24-2018, 03:55 PM
