Removing Cylinder Ring Gasket 82 911 SC
Hi,
Anyone have a trick to removing these? I made a few attempts using a seal puller but am concerned about buggering up the edges of the mating surfaces. Cross posting on 911 Tech
Thanks if anyone has any hints. Searched but didn't find anything.
Darwin
Old 06-04-2018, 08:28 AM
I had no issuer myself. Could you try with a high pressure cleaner (water). Might get wet and maybe not even work but no risk of damaging
80SC (ex California)
Old 06-04-2018, 09:32 AM
I just use the small screwdriver and distort the aluminum ring.
A set of needle nose will pull it right out
Then use a pick to clean the seal recess of deposits.
Bruce
Old 06-04-2018, 10:13 AM
A little tiny screwdriver did the trick, they were quite gooped in as a result of the broken head studs. I used a shop rag as a cantilever to avoid the screwdriver contacting anything but the ring. So much for the "proper tool" seal remover. Thanks Bruce
Old 06-04-2018, 06:20 PM
