Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E46 (1999-2005)
LinkBack Thread Tools Rating: Thread Rating: 2 votes, 1.00 average.
Push button start installation help needed
I am in the middle of installing a start/stop NQ-ST9001 and a Directed 556U Immobilizer Interface. I also have the Directed PKE 2102T but wanted to get the push button start working before installing the PKE. I problem I'm having is that the car won't start using just the Immobilizer unless I've first started it with the normal key or even just turned the normal key to ACC. Once I do that then remove the normal key the push button start will work consistently. The key I put inside the immobilizer module was working properly prior to installation. The start/stop module will also not perform the ACC, ON, OFF recycle mode, it will only do Engine Start/Engine stop mode. I suspect something is incorrectly wired, probably in the ACC circuit of the start/stop module but that's just a guess. Here's how I've wired the two systems:
Start Stop Module
Primary harness
Red 12V constant > Red/Green ignition
Black ground > chassis
Brown 12V interupted > Red/Blue ignition
Yellow starter > Blue/Black ignition
Blue ACC power > Violet ignition
White On > Green ignition
Secondary harness
White Oil path > Violet/Brown 12V brake switch
Yellow parking brake > Violet/Brown 12V brake switch
Blue brake light > temporarily wired to cigar lighter as I can't find the correct wire for 12V brake switch. Many online diy's say to use Brown/White at brake switch but this does not provide a switched 12V on my vehicle.
Yellow/Green/Gray > not used
556U Immobilizer
Red 12 V > Violet/Brown 12V brake switch
Blue status output from remote start > chassis
https://rodrigolascivo.com
La mejor lista de los sitios porno y NSFW más alucinantes!
Old 07-25-2020, 10:45 PM
