How to drain gas from E46 (2005 325xi)
have bad gas in car, stalled out and will not fire up. cranks like a bandit, but no fire. siphoned out as much as i could but still have about 1/4 tank. tank is plastic, any way to drain gas out ??? thanks
14t |
Sounds like a cam sensor-->why you thinking bad gas???
Did you check for spark @ plugs???? |
we put the gas in there from a boat
didn't realize it was bad, cat didn't go 1/2 mile before it konked out.
thanks. i may take out back seat to access the tank from the top, but i thought i could do it from underneath. thanks 14t |
NO cant be done from underneath unless maybe pulling fuel filter and crank car till it all shoots out
the fuel filter is back right corner right under bumber ??? its a canister filter, ?? i assume the filter is after the fuel pump, so the pump would be pushing the gas out to the filter vs trying to pull it through.
turning out to be a p - i - t -a . thanks |
NOt 100% sure on ur car, but most E-46 fuel filters are almost directly under the drivers seat.....there is a pnl you have to remove to get to it
Like BMWCowboy said the filter should be under the driverseat. Just pull the rear line into the filter angle it into a container and have someone turn the key to ON, but don't try to start it, and it should pump the gas out of the tank.
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 |
Oh and drain the fuel filter or replace it entirely.
