Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E46 (1999-2005)
Error Codes
Hi guys,
I own a BMW 3 series 2002 model that I have been using for about 2 years now. The Check Engine Light came on recently and it gave me the follwoing Error Codes
1. 06 - Fuel Injector, Cylinder #1
2. F3 - Misfire Detected, Cylinder #6
3. F5 - Secondary air System too low, Cylinder #1-3
4. F6 - Secondary air System too low, Cylinder #4-6
It will be appreciated if you can shed more light on this.
Old 02-23-2009, 01:38 AM
Oh!! and by the way, the car seems to run fine, no jerking or stalling just the pesky 'check engine Light' that comes on.
Old 02-23-2009, 01:39 AM
The Cleaner's Avatar
Just change to coil in number 6 and see what you get after a reset. Sometimes just a bad coil can throw a bunch or wacky stuff.
Old 03-02-2009, 07:22 PM
I would swap coils around and see if the misfire moves.
The secondary air is that fan that looks like a vacuum cleaner motor. It should start and run for a couple of minutes after a cold start. They use cheap bushings rather than bearings in the electric fan motor. so they don't last forever. Check to make sure that it is getting 12 volts after a cold start before replacing the fan. The relay could have failed.
Old 03-03-2009, 08:44 PM
