error code po366
hi there ,
ive been having a bit bit of trouble with my 320d e90. long crank before starting and every few weeks or so no start on crank and every light coming on the dash , traction control abs etc. This didn't show up any codes at all but always seemed to happen on prolonged drives from a stand when the car would die. if left with battery disconnected for a day the car would start up and run no problem, again no codes. My thought were crank sensor intermittent fault. So this week after reading some articles I thought I'd change the crankshaft sensor, see if this cured the problem ( rather difficult to get to, behind starter motor !!) So I've changed the sensor , very tight fit, original sensor on a 2006 car. Now the car won't start at all , po366 error code, on crank rev counter shows 300 rpm and sometimes jumps to 900rpm. I've also put in old sensor and tried , same results. sensor wiring checked 5v, ground, and fluctuations in sense wire. any ideas ? I did clean location hole for sensor with a cloth to remove any SPARF !! my thoughts now are 1: is the sensor sitting completely located 2: is reluctant wheel damaged , Bent, misaligned , coursing in correct signal .... I havn't got an oscilloscope multimeter.... thanks |
Administrator
Hi Roger,
Sorry to hear that you're having issue with your E90. Hopefully the tech article that I attached below will give you some insight and help into troubleshooting your exact issue. If you have any further questions, post a Comment below one of the articles and someone will get back to you with more info. I hope this is useful and best of luck! ![]() BMW 3-Series E90 (2006-2013) Technical Articles - Pelican Parts -Dmitry |
