Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
The never ending lean code
Po171
174. Bank 1 and 2 lean
Changed turbos
Valve cover and gasket
2 smoke tests performed.
No air duct leaks from what I can see
New symptom only once 29f1 (fuel pump plausibility ).
Not sure if that’s the fuel pump or something else causing the pump not to work properly.
Anything helps. I need an expert on e60 2008 535xi.
Old 03-13-2019, 01:41 PM
