Incomplete Outside Temp Display / 2001 540i
My outside temperature display is acting weird since the onset of colder weather this Fall. Not all of the bubbles / pixles /LED's are lighting up so many numbers appear incomplete. The temp degree sign is also missing.
All other gauges/dipays are working fine. Any thoughts folks? Thanks in advance. |
What's Facebook?
I know that this is a common failure among BMW cars. I have heard the solution to be as simple as re-plugging the connector to as complicated as having to replace the complete module. Good luck
Turborat "’Cause every once in while, the lion has to show the jackals who he is” 1979 911 SC - 2100 LB track rat 1986.5 928 5-Speed - 36,000 miles 2001 330Ci |
Thanks for the reply
Yeah, I didnt want to get in there and start monkeying around back there with all that electonics. I'll need to research the tech manuals. I wonder if the warranty covers this.
Patrick J. Leber 2001 BMW 540i / 6-speed / Sport Pkg 1983 Porsche 944 / Club Racer |
Patrick, sounds like the familiar display problem that appears to be prevalent amongst E39 cars. I have exactly the same problem on my 99 540 - except more of the display is effected eg odometer, mileometer as well as the service lights. The annoying part is the problem is intermittent and temperature dependent.
On a "ggod day" everything works fine.........for about 1/2 hour! I understand the problem may stem from a contact problem between the digital display IC's and the sockets which they plug into .........over time contact resistance builds up and the display becomes intermittenmt and appears to be faulty. Annoyingly it's a $1 problem but getting inside the speedo housing to fix is not for the faint hearted. Inthe US I understand that BMW in North America have a replacement program ( they replace the whole binnacle) Here in Australia it seems customers are "on their own".......faced with a hefty bill @ $2K. But the rest of the car is so good(!) |
Thanks........2K!!!!
Wow, that alot of cash to fill in the blanks.
I'll lean on the dealer to see if it is covered on my extended warranty. I bought the car dealer certified. Thanks again. To be continued....
D idn't E arn I t
there's supposedly a recall and a goodwill fix for this. Someone hit 'em with a class action lawsuit.
In the movies only bad guys sleep in king size beds. |
