Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
Squeaking noise
OK.. this is driving me crazy.
I have a 95 (early 95) 540i. It has an intermittent squeaking that seems to come from the right front brake. It changes speed with the car, and sometimes with a change in direction.
I have replaced the front rotors and pads (twice) the front wheel bearings, the tires (probably not relevant) and rebuilt the whole front suspension. I have pulled it apart multiple times, and still can't find the source of that damn squeak!
Anyone have this same problem?
Clay Perrine
74 914 1.8L (Frodrick)
73 914 /6 4.0L 964 motor (Igor)
70 914 /6 Factory Six. (Elwood)
95 BMW 540i (Inga)
Old 01-31-2007, 08:32 PM
Jeron's Avatar
Describe it more.
Only when braking? Constant while in motion? Over bumps? A scraping, a rattling? how do you know it from the brake? How about in reverse?
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 01-31-2007, 11:53 PM
The Cleaner's Avatar
check the wheel, try a different wheel on that side and see what
happens
Old 02-01-2007, 03:17 PM
It is a constant squeal that changes pitch as the car changes speed. It sounds just like a brake pad squeal. It stops when the car stops.
I have rotated the tires, and it didn't help.
Clay Perrine
95 BMW 540i (Inga)
Old 02-02-2007, 07:43 PM
Jeron's Avatar
Just gonna throw out a few ideas:
Metal splash guard behind the rotor
Foreign object in the area of the ABS sensor
Tranny itself
Foreign object rubbing the drive shaft
Does it make the noise if you spin the wheel in the air?
Old 02-03-2007, 10:49 PM
I have had the wheel and rotor off multiple times. I can't get it to squeak up on the lift.
When I pulled the hub and replaced the bearings I didn't see anything around the ABS sensor... but its possible I missed something.
I never though of the driveshaft... I am going to have to get it up in the air and take a look, just as soon as my 914/6 is off the lift.
Clay Perrine
95 BMW 540i (Inga)
Old 02-04-2007, 06:04 AM
