Can I use a E28 528 starter on a E28 535?
Does anyone know if a starter from a E28 528 will work on a 1987 535is? Or does the starter have to be one for a 535?
I am trying to be a cheap ass and buy a started at Pick a part and it is almost imposable to find a 535.
apparently not. I selected the part number of an 1987 535 with manual gear, left hand drive and the starter part number I then pasted into the cross reference and it shows these other cars
http://www.realoem.com/bmw/partxref.do?part=12411272150 Part Cross-reference Part 12411272150 (Rmfd- STARTER MOTOR) was found on the following vehicles: E12: Details on E12 E12 528i Sedan E12 530i Sedan E23: Details on E23 E23 733i Sedan E23 735i Sedan E24: Details on E24 E24 630CSi Coupe E24 633CSi Coupe E24 635CSi Coupe E24 M6 Coupe E28: Details on E28 E28 533i Sedan E28 535i Sedan E28 M5 Sedan E3: Details on E3 E3 2500 Sedan E3 2800 Sedan E3 2800Bav Sedan E3 3.0S Sedan E3 3.0SBav Sedan E3 3.0Si Sedan E32: Details on E32 E32 735i Sedan E9: Details on E9 E9 2800CS Coupe E9 3.0CS Coupe So maybe the easiest is one from an E32 735 which also has the M30 engine.
SHOGUN'S TRICKS AND TIPS FOR THE SEVEN SERIES http://twrite.org/shogunnew/topmenu.html |
Thank you, I need to print those out and hit up the junk yards.
