Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
unindicted co-conspirator
looneybin's Avatar
'88 528e timing belt replacement question
I'm usually on the Porsche side of the board, but i just picked up an '88 528e for my son & want to change the timing belt, as i don't know when it was last done.
Is there a site to go to for repair diagrams (please don't say Haynes) for the belt replacement procedure.
Also any "while you are in there" items i should look at, like maybe water pump & tension roller?
Thanks for the advice
Brent
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 12-28-2011, 09:14 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
You should replace the water pump while you're there. It's very easy.
Take a look at this..
Pelican Technical Article: BMW E30 Timing Belt Replacement
In this article, the car is an E30, but the engine is basically identical in your car.
Old 12-29-2011, 08:09 AM
looneybin's Avatar
thanks for the article
I've changed the belts & pump on my 944, so this shouldn't be too difficult.
famous last words, i know
Old 12-29-2011, 08:58 AM
You're right. This is MUCH simpler than doing it on a 944.
Old 12-29-2011, 10:30 AM
