Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
Mechatronics issues and Programing???
2007 BMW 530xi automatic, 220,000 miles
Hello All,
Short story quick:
My BMW's transmission began slipping (as I felt) earlier this year. The slipping was only noticeable while accelerating. Took it into the BMW dealership and the tech found no code issues but did find a minor leak so they replaced mechatronics sleeve and pan. He felt the slipping was actually a miss caused by one of the coil packs. I didn't agree but I went ahead and changed all of the packs myself. The slipping continued and one day I did briefly get a transmission error and it went into fail safe mode. That error went away immediately and the slipping improved over the next few months to the point it wasn't discernible. So I thought possibly cured.....
The car performed perfectly for the next few months. Then recently I got another transmission error and it goes into fail safe mode. When I park the vehicle it won't now release out of park; minus manually lifting locking mechanism under shift boot.
Anyhow, INPA now gives the following code errors.
1) 002AD0....no message from transmission control unit, receiver DME, transmitter EGS/SMG
2) 004E24.....EGS: Electronic pressure control valve 5
3) 0054C6.....VTG: Oil Wear
The BMW technician made me aware of the transfer case Oil Wear issue earlier this year but recommended not changing it. The other two errors are new. I ran INPA/WinkFp on it myself.
INPA states the mechatronics needs to be replaced and from my research that seems to be the most likely culprit? So I have purchased one from a BMW of same make/model.
1) Do you have any insight and do I seem to be on the right track?
2) Should I only go with the ZF automatic transmission fluid or is Pentosin ATF1 acceptable? How can I verify that Pentosin is acceptable because some say it's ok whereas others vehemently say stick with ZF and most definitely don't mix them. Just FYI, If I keep the car I will probably change the trans oil and pan after each 40k miles here out.
3) Should I try to re-use my TCU or go with the new mechatronics TCU. That vehicle had 102k miles on it. I just don't understand if my TCU may have a problem also given first listed error 002AD0?
Your insight and suggestions is appreciated.
God Bless,
Ralph
Old 10-27-2017, 07:52 PM
