I NEED HELP!!!!!!!!!
MY DISPLAY SWITCHED OVER TO GERMAN, I NEED TO KNOW HOW TO TURN IT BACK TO ENGLISH. ANYONE WHO CAN HELP PLEASE EMAIL ME!!!!!!!!!!!!!!! DAGERM50@AOL.COM
Which display? Gauge Display or OBC? I remember the Bentley manual discussing the proper steps to take. Let me know what display, and I can probably help out.
To change the OBC operation from metric to US units, press the AVG MPG button, and then the press the changeover contact button with your ball point pen.
Complete instructions are available at: http://home.att.net/~ebaines/e28_obc.htm Later, |
I HAVE A 89 750IL
AND I CANT GET THE CODES. I TRIED AS THE MANUAL SAYS TO PRESS THE ACCELERATOR 5 TIMES AND WAIT FOR THE CHECK ENGINE LIGHT. NOTHING! ANY ONE GOT ANY SUGGESTIONS??? HELP!!!!!!!!!!!!!!!!!!! |
OBD II trouble codes and how to display
Remember the WOT, Wide Open Throttle, switch is the signal sensor to the ECU to display the codes.
If you have a modified ECU chips, some vendors fail to include the OBD II code in the modifed chips. 1. Sit in the driver's seat. 2. Turn the ignition to the On position, but do not start the engine up. 3. Immediately depress the accelerator fully and release fully 5 times quickly. 4. Wait for a few seconds and you will see the Check Engine light flash once, then start it will start to blink. All codes are comprised of 4 digits. The number of blinks corresponds to the fault code. For example, ON then pause, ON ON then pause, ON ON ON ON then pause, ON ON ON then off would be a 1243. 5. Each four digit code will be flashed sequentially. When the codes start to repeat, all stored codes have been displayed. 6. Turn the ignition off and check the codes with the table below. 1444 and 2444 means no problem and that is what you hope to find! Good luck! http://www.bimmerzone.com/fcodes.htm BMW Diagnostic Flash Codes DME Version --> M1.x M1.x M3.1 M3.3 M3.3.1 Malfunction MCU 1 MCU 2 DME Control Unit 1211 2211 1211 1211 1211 Air Mass/Volume Sensor 1215 2215 1215 1215 1215 Throttle Potentiometer 1216 -- 1216 1216 1216 Output Stage, Group #1 -- -- -- 1218 1218 Output Stage, Group #2 -- -- -- 1219 1219 EGO Sensor #1 1221 2221 1221 1221 1221 EGO Sensor #2 -- -- -- 1212 -- Lambda Control #1 1222 2222 1222 1222 1222 Lambda Control #2 -- -- -- 1213 -- Coolant Temp. Sensor 1223 -- 1223 1223 1223 Intake Air Temp. Sensor 1224 -- 1224 1224 1224 Knock Sensor #1 -- -- -- 1225 1225 Knock Sensor #2 -- -- -- 1226 1226 Knock Sensor #3 -- -- -- 1227 -- Knock Sensor #4 -- -- -- 1228 -- Battery Voltage/DME Main Relay 1231 2231 1231 1231 1231 Throttle Idle Switch 1232 2232 -- -- -- Throttle WOT Switch 1233 2233 -- -- -- Speedometer "A" Signal -- -- -- 1234 1234 A/C Compressor cut off -- -- -- 1237 1237 A/C Compressor -- -- -- 1242 1242 Crankshaft Pulse Sensor -- -- -- 1243 1243 Camshaft Sensor -- -- -- 1244 1244 Intervention, AEGS -- -- -- 1245 1245 Ign. Secondary Monitor -- -- -- 1247 1247 Fuel Injectors (group #1) 1251 2251 -- -- -- Fuel Injectors (group #2) 1252 2252 -- -- -- Fuel Injector #1 -- -- 1251 1251 1251 Fuel Injector #2 -- -- 1252 1252 1252 Fuel Injector #3 -- -- 1253 1253 1253 Fuel Injector #4 -- -- 1254 1254 1254 Fuel Injector #5 -- -- 1255 1255 1255 Fuel Injector #6 -- -- 1256 1256 1256 Fuel Injector #7 -- -- -- 1257 -- Fuel Injector #8 -- -- -- 1258 -- Fuel Pump Relay Control 1261 2261 1261 1261 1261 Idle Speed Actuator 1262 -- 1262 1262 1262 Purge Valve 1263 2263 1263 1263 1263 EGO Heater 1264 2264 1264 1264 1264 Fault Lamp (check engine) -- -- -- 1265 1265 VANOS -- -- -- -- 1266 Air Pump Relay Control -- -- -- 1267 1267 Ignition Coil, #1 -- -- -- 1271 1271 Ignition Coil, #2 -- -- -- 1272 1272 Ignition Coil, #3 -- -- -- 1273 1273 Ignition Coil, #4 -- -- -- 1274 1274 Ignition Coil, #5 -- -- -- 1275 1275 Ignition Coil, #6 -- -- -- 1276 1276 Ignition Coil, #7 -- -- -- 1277 -- Ignition Coil, #8 -- -- -- 1278 -- Control Unit Memory Supply -- -- -- 1281 1281 Fault (code) Memory -- -- -- 1282 1282 Fuel Injector Output Stage, no cyl # -- -- 1283 1283 1283 Knock Control Test Pulse -- -- -- 1286 1286 No Failure 1444 2444 1444 1444 1444 Later, |
