Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 6,7,8-Series Technical Forum
Send a message via AIM to operationcougar
BMW Roundel purchasing a 740i, questions
well im a usual on the other side of this site, as i own a porsche, but i went to the bank earlier and i got some money out so i can go buy a car in the next few days. ive had my eye on a local owned '95 740i, very clean drives great and exactly what im looking for, but what i was wondering was;
1-the car isnt without any problems, the first one is the power seat/steering wheel adjustments are in operable, what i mean is, i cant adjust anything on the seat, and i cant raise/lower/move the wheel (other than basic turning functions) is this a relay, or fuse, just something else simple (hopefully) or am i taking a chance that every one of the motors has been burnt out?
2-also does anyone know if there are any major problems with this perticular car that i should look out for?
this will be my first BMW but by far not my first "car" so dont worry about explaining anything in lamens terms, i can handle the real stuff
im also unusualy excited about this purchase... and i dont know why... but you probably cant help with that
95 - BMW 740i (daily driver)
02 - kawasaki mean streak (nice weather driver)
RX-7 built of other RX's (and a good place to throw money) (sold)
z31 300zx vg30det+ (new money sucker)
Old 07-07-2005, 02:35 AM
also while im thinking about it, another thing is; how costly is replacing the whole dash stereo and climate control unit, actually i really dont want to replace it all, its just that some of the l.e.d.s arent lighting up so you really cant see whats going on in some of the spots
thanks any help is great
Old 07-07-2005, 02:51 AM
sorry, one more try to get it all ^^^ i ment to say the LCD (not LED) is bad, i belive the term to use would be that its "pixilated"?
thanks
ian
Old 07-07-2005, 02:54 AM
Send a message via AIM to Bear
1995 740
Teh biggest problem in the '94-'95 era was the NIKASIL engine (high suphur content fuel in this country wreaked havoc with many of these engines to the point that BMW extended warranty and even replaced engines with a ALUSIL engine)> Go to KOALAMOTORSORT.com and check out this problem.
Old 07-07-2005, 07:09 PM
thanks, thats great advice i will definatly find out what block is in the car
ian
Old 07-08-2005, 02:01 AM
and it was purchased!!! got a great deal on it if i dont say so myself, beautiful as well, ill get some pics up if there is an intrest :-)
Old 07-14-2005, 01:30 AM
but also, why is my parking indicator on even when the car is off, and the key is in the ignition?
thanks in advance
Old 07-16-2005, 04:50 AM
Parking Light
Is key in the on position when you have this issue? If parking light is on (indicator or the acual light?), what position is turn signal lever and do you have the actual parking light on.
Answer these and we will go from there.
Old 07-16-2005, 05:48 AM
no the keys off, and out of the car. this is the indicator located next to the shift boot. the turn signal is in the off position as well
Old 07-17-2005, 03:21 AM
Parking Indicator
I think I was confused, is this the "P" selection on the gear shift indicator on shifter console?
Old 07-17-2005, 04:50 AM
"P" indicator
Here is what my Buds at ROADFLY say: Normal for 15-30 minutes after shutdown, check to see if it really never goes off (after 30 minutes).
Old 07-17-2005, 04:54 AM
ahhh, actually last night i did "sneak" up on the car and, yes it was off, i guess i just thought it was on all the time because when you unlock the car it also comes back on. so basicly anytime i was around the car= it was on
Old 07-17-2005, 09:46 PM
Park Light
Ah, yes. The longer you own the car the more strange things you will discover about it. I do not believe that even Klaus (my generic Bavarian) the builder knows everything that goes on in his cars.
Old 07-18-2005, 05:54 AM
also, my drivers seat will not adjust, nor can i use the power tilt and teliscoping functions on the wheel, my mirrors still work with the memory system though
do i have a burnt relay?
Old 07-24-2005, 04:30 AM
740il
Check fuses 42 and 43 (under rear seat in rear power distibution box) and replace if necessary. Also in front power distribution box (under hood) check fuses 17/20/21.
Old 07-24-2005, 05:26 AM
pics
pics of the new baby, little grainy but i cant reshoot, its too dark now
http://www.photoworks.com/albums/pictures.jsp;jsessionid=4AFF8460DDE313B7105E802964 671956?reset=true&id=37673324&cb=PW&svr=web7?Cmd=RefreshCs&User=iandennis_84@hotmail.com&ts=1122967061867
Old 08-01-2005, 11:56 PM
