2001 R1100S - Parked for 15 years...
I just picked up a 2001 R1100S with only 1800 km. It was parked indoors by the original owner untouched for 15 years. Other than a non-functional fuel pump, everything seems okay. I have changed all fluids, including the ABS servo fluid (I have an RT with the same system), replaced the battery, and have a fuel pump and tires arriving today. Is there anything else that I should be checking? Are there any common problems with these bikes?
Does anyone know where I might find the rear signal light holders (part 63132306801)? The bike is in amazingly good condition with the exception of two broken signal lights...
Thanks.
Old 04-29-2021, 06:23 AM
As most of us spent many years walking past our bikes and knocking them off..anything but OE will do, and if it’s clicks...assume either Europe or Canada.
XR1000
K1200r Sport
XT660
Tiger 955
R1100s
Old 04-29-2021, 10:26 AM
Talk Less, Say More
ckcarr's Avatar
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
Rubber brake lines rot and can then pop when hard braking. Check them or just replace with Speigler or other braded steel ones.
cRaIg CaRr
2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer.
Old 04-29-2021, 10:55 AM
Mine had a rear turn signal hanging when I bought it. Max BMW has then in stock online. www.maxbmw.com
2001 RS1100S Light. Black on Black w/carbon fiber bits.
Old 04-29-2021, 02:10 PM
908/930's Avatar
Wow, 1800km. Put new tires on it, after 15 years the rubber will be hard. As ckcarr said new brake lines, and fuel lines.
Old 04-29-2021, 03:49 PM
Been Nowhere Done Nothing
Swamper's Avatar
1800km like in 1100 miles?
05 R1100S BCR, 04 R1150R
16 S1000XR, 24 S1000RR,
21 Ducati 950S
Old 04-29-2021, 05:36 PM
Canadian bike - Yes equal to 1100 miles. Installed the new fuel pump and a set of Road 5 tires today. Runs and feels great. The fuel and brake lines look and feel fine. I will replace them either way. Looks like it will be a good addition to the herd...
Old 04-29-2021, 08:06 PM
While the easy option is to ask questions, to say there is a mountain of info on this board is an understatement, and if you want a UK perspective look at Boxertrix.
XR1000
K1200r Sport
XT660
Tiger 955
R1100s
Old 04-29-2021, 10:13 PM
Thanks. I have done lots of reading and will continue to get through everything that is here. No shortage of info...
Old 04-30-2021, 04:24 AM
908/930's Avatar
With the brake lines the important part is what you can not see, the previous owner of my bike told me that about three years ago he was moving the bike in the garage and applied the front brake and the line developed a split, said visually they looked good. I'm not sure what they use for reinforcement in those original lines.
So was there a story why your bike sat for so long?
Old 04-30-2021, 08:11 AM
Talk Less, Say More
ckcarr's Avatar
My brake lines looked good on the outside. However, when I would squeeze the front brake lever I would observe a big bubble swell up. I was sort of fascinated with it...
Then when I ordered and received the Speigler braided lines (which can be ordered in a black retro finish to match the original bike line colors), I squeezed the brake lever with the original line still connected.... And didn't take much to pop and blow brake fluid all over...
cRaIg CaRr
Old 04-30-2021, 10:08 AM
Buzzz's Avatar
I had the issue on my previous S, and it was "only" 15 years old at that time. Luckily, I replaced the brake lines before they pop.
R1100S / VIN ZA84895
Old 05-01-2021, 09:46 PM
Fuel filter? Purely from an age pov.
That’s a nice find!
Old 05-04-2021, 12:02 PM
Buzzz's Avatar
And fuel lines for sure.
Also make sure you release the zip ties constrains on the wiring harness, especially near the Neimann.
And check the clutch slave cylinder. Buy a replacement paper seal to replace the old one, even if the cylinder is fine.
For a machine that old, with so few miles, the MoS2 grease on the spline must be gummed. If you have the possibility, disassemble the transmission and clean/regrease all the splines.
Be also prepared for a rear engine seal failure.
I don't want to alarm you, but finding such a bike is not necessarily a budget buy.
Old 05-06-2021, 12:45 AM
pwillikers's Avatar
https://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/756200-front-brakes-sticking-diagnosis-please.html#post7543121
Paul. '11 R1200RT, '09 Buell 1125cr, '08 Suzi SV650A, '00 Suzi SV650, '97 328i (with sticky ass tires - I love this car). And the bikes I used to own: '68 Bultaco 100, '69 Honda CL450, '71 Kawasaki Mach III, '71 OSSA Pioneer, '72 Honda MR175, '72 Benelli 250, '75 Yamaha RD350 (then college), '83 Honda VF750F (then kids),'96 MZ Skorpion, '99 R1100S, '01 SV650, '94 Honda VFR750F and '04 R1100S w/Öhlins an' stuff, most wrecked.
Old 05-06-2021, 09:41 AM
pwillikers's Avatar
And a big +1 on replacing the rubber fuel lines under the fuel tank. Mine were rotted and leaking which I discovered by sensing the evaporative cooling of my right pant leg due to the fine mist of gasoline emanating from the leak - very exciting it was.
Old 05-06-2021, 09:49 AM
Twisty Mt Man
Replace the left cylinder’s cam chain tensioner with the updated one, a know issue with the original will cost you an engine.
Old 05-10-2021, 08:54 PM
BigDav's Avatar
In the first 10k miles I had replace the fuel pump and in-tank fuel lines, brake hoses, crank sensor, cam chain tensioner, headlamp bulbs and the tire valves rotted out of the rims.
I like to complain that it's the most unreliable motorcycle I have ever owned. But still, I love riding it.
Old 05-31-2021, 09:27 AM
macadamia's Avatar
BMW Roundel
Nice find! Have fun with rebuilding it to its former glory. If you got it for a song, that's even better.
I just started to rebuild mine. It is a 2002 R1100S Boxer Cup Prep I bought it from the first owner in 2010. I rode it for a couple of years until I got an 2012 R1200GS Adventure. It has basically sat since. I moved to my new location in 2014 and rode it from the moving truck to the underground garage of my apartment where it sat until I moved into my new home last year. I sold my GSA in 2015 so I have not ridden in a while and want to fix mine up and get back into riding. I have 55k miles on the Boxer Cup Prep.
I took the tupperware off of it earlier this week and removed the battery. It was all swollen and ruined; luckily it was not leaking. Since I had to remove all of the gasoline to move it back in 2014 and it has not had gas in it since, I plan to replace all of the gas tank internals (fuel pump, filter, fuel lines) and all of the external fuel lines before putting it back in service. I will also start to assemble the parts needed to replace the clutch, but I will wait until next winter to do that unless it is absolutely necessary. I have an HID headlight out so I'll need to get a new module for it. I have a broken rear turn signal that needs replaced. I have a new one ready to install. I'll need to get new tires, new brake lines, do a complete brake fluid flush, oil change, rear seals were replaced in 2012 but I'll need to change the fluid again, and I'm sure I'll find more as I tear into it.
I am hoping to be able to ride it this summer, so here's to the project.
"No matter where you go, there you are..." Buckaroo Banzai
2018 BMW X3 M40i; 2002 BMW R1100S BCP; BMWMOA Member
Old 06-04-2021, 03:03 PM
