lean condition when dyno'd-UPDATED 3 MAY 2003
hey gang, lennie, roger, duanne, et al...had the bike dyno'd today and appeared to be lean through out. setup is the induct, k&n, staintune and FIM to suit. i gained 2-5hp everywhere and torque was nicely improved. the tech recommended trying the ne techlusion as they use factory cables instead of wire splicing. their thought was that if more fuel could be delivered up high that peak hp would improve. the bike runs great and pulls hard, but i have to wonder if maybe a different ap might do better? any thoughts on this? thanks in advance.
repoe3 |
Interesting. How confident are you in the Dyno operator? That is pretty exactly config that chip is meant for, so that would suprise me. What is his indication that it is lean. Duane and Brad and Lennie could better speak to this than me, but it strikes me as a bit odd. Of course, it could help the techlusion sales :) I'm skeptical you'd gain much from it.
When you said you gained 2-5, what versus what configuration is that based on? Bone stock vs all of those items? I want to make sure I'm following this right. roger |
Repoe,
How was it determined that your bike was running lean? At what RPM range? 2-5 HP is respectable with the Staintune/FIM set-up???? Let me know. Robert Foster Foster Design |
this dyno was plotted against my stock baseline. the operator inserts the sniffer up the tail of the bike to monitor the mixture. one thing i did not mention was that the peak hp was 85 that is only 2 up from the baseline, but as stated, there was upwards of 5+hp throughout the power curve. it was an improvement, but not what i was expecting. the FIM chip is the one for exactly my setup. it has me in a qaundry as well.
repoe3 |
Repoe,
Lean as compared to???? Other bikes??? BMW's run lean, that is the motronics job. But how Blue is blue???? How lean at what rpm? Just trying to help. Robert |
i wish i had a bit more information, but until i get the printed results showing fuel mixture at various rpm's i am short more info. the mix seems okay for the most part it is only up at the top that if it had more fuel, it would have a bit more zip. regardless of that, my header pipes look to be expected having owned several R bikes between my father and myself. nothing too blue, plus the tail pipe exhibits a nice dark color at the exits. the plugs seem okay for the most part. hope to get the proper printout this week. i was there during the dyno and watched the meter on the screen as it travelled into the yellow/red zones monitoring the mix. firebolter also had his firebolt dyno'd and his mix was spot on. between the questions you all can ask and the answers i can obtain we can come up with some great ideas...i am trully optimistic. but i do maintain some doubt in the dyno. having witnessed many dyno's there is not a lot to it and all the bases appeared to be covered.
repoe3 |
Repo,
Was your cat code plug pulled??? Robert |
no, the question as been asked and difference concerning the cat code with the FIM chip is that it made no difference. are you suggesting that i remove the plug? from my understanding the FIM chip has all eight possible maps (in regards to the cat code plug) so that it does not matter whether it is in or not.
repoe3 |
okay i have removed the infamous cat code plug. while i will not be able to dyno the bike anytime soon, i will ride without it tomorrow (i will bring it with me of course should it start acting funny)...but i have to believe that i wont see a major difference. of course iu will be dreaming all night that tomorrow when i power up it will be a new bike and see it is that part of the dream that my alarm wakes me up and i return to reality.
repoe3 |
TAKE THE CAT CODE PLUG OUT.
Don't trick the motronic! Cheers, Robert |
Pullling the cat code is not supposed to make a difference, since the plug just selects a map, and each map on that chip is identical, no?
Otoh, I too would like to know how lean. If you boosted 5hp midrange and 2hp peak, then you can't be far off. That's a small, but appreciable and realistic gain. Where the difference should really show is in roll-ons as you shift through each gear. That's a better indicator of the modest, but nice gains you'll get in everyday driveability. Let us know when you have more data pls. roger |
mine would always make more dyno hp with the std chip over the fim chip in the tune/duct combo, as the fim duct chip top end was too rich on the dyno i use. i've got lots of runs to prove it. the fim chip works lots better on the road tho.
strikes me as very odd they would say it's lean. is your fuel filter ok? good fuel pressure? i would expect it to lose "dyno" power as compared to std with that combo. the code plug makes no diference with the fim chip. well, it shouldn't. |
Greetings,
The next time someone evaluates a chip, do it with and without the cat code plug. It is worth the time. Made a positive difference on all chips we tested this winter. Remember marketing plays a big part of the spiel that chip manufacturers use to promote their product. Question, how do you change maps on the RhineWest Chip and the BBP Chip to conform to the level of mods on your "S"? Especially, the BBP chip? Cheers, Robert Foster Foster Design |
So, are we saying the manufacturers of some chips lie when they say each map are in the ROM is the same? You're either saying they are lying under the guise of marketing, or you're not. I think if FIM says they've put each map the same, then it's true. Maybe I'm naive.
Do you understand how the cat code plug, or any chip works? The Rhinewest and BBP do use the plug to select the map at system boot time. Personally, I use a 3 position switch that allows me to simulate the 3 different cat code plug configurations that are of interest to me. So, on some chips, just blindly/dumbly pulling the plug will help. On others, it will do nothing. On some of the BBP chips, it will actually be worse (at least one knowledgeable lister has his maps 2 and 3 coding selction reversed from the way my bbp is programmed. For me, pulling the plug does select the middle of 3 map, which is the best suited for my config. For the guy with the reversed map, it would be worse. Note on any chip with more than 2 maps, it's not just a question of pulled or not pulled. That will access, at most, only two maps. Don't know which scheme that RW has chosen other than it to is of course selected via a plug (i.e. I don't know if one plug vs another plug, or the stock plug vs none, or a non-stock plug vs none) So, think instead of just pulling. Know your map and your chip and don't just go ripping stuff out. The rest of Robert's questions sound like just the right ones though. I'd look at the filter or pinched line too. Since they're no real mixture measurement in open loop mode (which you're in all the time when dyno-ing) then the system has no way of knowing that it's not squirting as much fuel as it thinks it is, is something is amiss (such as pinched line, clogged filter, faulty pump, clogged injector etc etc) |
Roger and others with selectable maps, what stage for what situation?
I have the BBP and a 2 position switch to switch between stage 2 and 3. I *think* that with stage 2 I have a higher top end, with stage 3 more midrange power although it is quite hard to do a fair comparison. Each run on the freeway on Sunday morning :))) is different, a bit more wind, less concentration, you know how it is. Anyway, what should be the best setting according to your experience? My setup: K&N air-filter Lennie's Induct BB Power chip K1200RS Fuel pressure regulator Laser Cat eliminator Brisk race sparkplugs |
Hi Rob,
My setup is very close to yours SJ Powerfilter w/K&N air-filter Lennie's Induct BB Power chip Stock Fuel pressure regulator Laser Cat eliminator Stock sparkplugs Normally, with stageII giving more apparent topend than 3, I'd say something was amiss. In this case, if I had to make a guess, I'd say that compared to me, you have a slightly more restrictive filter setup, and a bunch more fuel, implying rich running. Probably a bit over-rich. Given that, it might make sense that stage two, which ought to be leaner, bring your mixture back towards optimal. I think it's hard to do a fair comparison too, other than maybe a bunch of timed roll-ons. I have my BBP wired similar to yours. Except that since mine is mapped a bit differently (I remember comparing to yours a long while ago) I have to set my switch differntly. I happened to find a wiring setup that would select stage two in one position of spdt and stage two in the other. Since mine goes to stage-3 with no connection (I think your 2 and 3 were reversed compared to mine) then I was able to swap in a spdt with center-off and end up with a stage 1/2/3. Anyway, I'd temporarily jumpered mine for stage-4 and it rolled on a bit slower. I attribute that to being over rich. Your K12fpr may give you a similar, if not identical situation. My setup really likes position 3 currently. You have less air and more fuel, so I'd GUESS that stage-2 is better for your setup. Tough call and just conjecture, but I'd lay money on it being right (just not much) :) |
have my doubts about the lean issue...
back from 300 miles through the virginia hills, big hills, fun hill, wine country, blah blah blah...as would be expected there was no difference between running with vs. without the cat code plug. albeit, i did not dyno it, but the ccp does not appear to affect the FIM chip. early on, i remember people saying that the setup with the FIM chip actually did make a weird top end on the dyno. damn i wish i had that print out, anyway, today roll-ons (as usual) did not indicate a plateau of power like the dyno chart indicated. i hit the rev limiter and it never seemed to stop pulling, that is until the rev limiter kicked in. i guess what i am saying is that i doubt i have any mechanical issue with the bike. no difference between gas mileage without the ccp. but wait one second, the difference in removing the ccp is dramatic as it removes at least an ounce from up high. that helps the bike turn in faster, smoother. i was able to scrub my rear tire in to the edges too. all kidding aside, the improvement in ridability and power/torque of the bike is significant. while i may be intrigued to pursue other options...one thing is for sure is that from the baseline on the same dyno, everything improved. i will just keep searching for dynos that will report a higher hp reading and leave it at that :cool:
repoe3 thinking he might want to try the rhinewest chip just for the fun of it. |
I recently had a chance to have my S dynoed .....
4 pulls were made with a peak of 88.4 at the rear wheel. Unfortunately, the last change to the setup I made a few days later > exit the cat-code plug. For now, it's just a number out in space as I don't have any future plans on having it dynoed again. Current mods include: Vanderlinde exhaust and chip, in a 2001 ecu (my bike is a '99) Induct San Jose powerfilter assy. stock regulator cat-code extermination I performed all these mods one-at-a-time! That includes the exhaust BEFORE the chip. I'm always interested in potential changes from each source alone. I've heard/read much discussion over the potential benefits of adding a chip/exhaust/induct, etc. I can say, without a doubt, each of these mods produced or changed power. The exhaust and airfilter brought up the mid and top end, but suffered the low. The induct made a very noticable difference, especially when accelerating through and over 70 mph .... nice. As some of you might want to know, the chip install actually brought back everything that had been lost on the low end! Before, I had to be over 3000-3500 to experience smooth acceleration. Afterwards, it's no problem to roll-on from 2500 or even lower. Nice to have the original balance back in the powerband. I'm still experimenting with the cat-code plug. I think it has actually helped the top-end most as it doesn't seem to nose over near redline/rev-limit. As an interesting sidenote, I was able to run the bike down the 1/4 mile this past Friday night. First run was the best at 11.88 @ 113.12 mph! Not bad for a touring bike. The bike was very consistent. Turned out it was a rain-delayed Streetbike Shootout that night and I managed to get 3rd place in a 33 bike feild running against prepped Hyabusas and Kawasakis! Add another area this bike outperforms in! |
I was wondering, does anyone know the calculations for correcting horsepower if you know what the weather conditions were?
Thanks, Tom |
Roger, thanks, excellent explanation. I very much guess you're right. Also given the fact, totally forgot to mention, that with stage 3 I have a great afterburner effect with flames coming out of the tailpipe! And loads (much more than with stage 2) black stuff on my licence plate. I guess that has to do with the richer mixture.
I'll switch back to S2 next time I take her out! |
Hi Rob
Very welcome. The extra info you provided does seem to confirm even further that theory. Tom, where'd you do your dyno work at? thanks roger |
Austin Sport Cycles had a dyno brought over for a Saturday to run for their 'dyno day'. They're over on 620, not far from my shop.
It was a pretty cool setup. It's a Dynojet, installed in an enclosed trailer with side doors that open so you can watch them torture the machines right there. Bikes that were run that day varied from a Triumph cruizer to Harleys to Gixxer street and race bikes; even a couple Kawasaki turbo bikes made the show for top honors. Anyway, my bike made 88.4 on the 4th run, as I stated earlier. I wish I would have had the forsight to remove the CCP, but alas I did not. It's really a smooth curve from ~4500 all the way to rev-limit, but peaking at 7800 or so. People were remarking that this dyno seemed to be a little "low", but that could have been due to the atmosphereic conditions, esp. the humidity. I would have liked to se over 90, but now I have something to shoot for ..... NOS anyone??? Roger, Did you ever get yourself a shorter TA? Tom |
http://www.charlotte.homeip.net/sacborg/r1100s-dyno.gif |
I have the Vanderlinde chip in my bike and AM running it with the CAT CODE Plug. Does it make any difference with the Vanderlide chip to remove the plug?
Squid,
That curve on your printout looks very similar to what repoe's was like Saturday, although his top was 88 hp. Seems really erratic, wonder why the S curves look that way? Conversely, the curve on my Firebolt which I did saturday right after repoe's run was a nice building, constantly climbing, relatively linear curve that peeked at 73 hp. Weird, wonder what causes that dip at 6200-6700 rpm's? You certainly don't feel that when riding as it is a strong pull all the way up to ~8000............... I'm gonna take my S up next time to baseline it just for grins......Should be similar. |
Different dynos...different days...different weather...different operator...
unofficial corrective HP numbers...
after factoring in a power of two (2), the S miraculously increased its power to about 160HP. okay so i lie... repoe3 |
continuing the question
we reached a concensus that the TPS really only affected low throttle positions, correct? so tweaking that would not affect the WOT? aside from the bbp chip and its adjustability and a custom power commander application, what other creative ideas can we come up with to tweak the EFI? anyone running the rhinewest chip with staintune/induct? anyone running the FIm that is not tuned for the induct, but running the induct anyway? questions questions. i thought EFI was supposed to make tunability easier than carbs...what happened to that logic?!?!?
repoe3 |
That logic is flawed in cases such as this, where you have no real end-user tuning hooks (can only blindly swap chips) and where the system has no air measurement.
And, you're absolutely right in pointing out that messing with the TPS will not affect this at all. Utterly irrelevant. You have about 4 options. Tweak the regulator, tweak the chip, tweak the motoronic via a piggy-back unit (PCIII, Fuel Nanny etc) or pull the cat code plug on a stock Motronic (which affects closed loop operation, but therefore shouldn't affect WOT either.) EFI is a LOT easier, IF you have a good rolling dyno and the right software. Otherwise, a lot harder. |
hmmm, fuel regulator. where is that located on the bike and how much do they run? any real data on what it does (i know it regulates the fuel) i mean like increasing boost on a turbo by X, that kinda data? i have to wonder if not every engine responds exactly the same way with the same mods, given manufacturing tolerances. the dyno tech even said looking at the curve, if the bike was carb'd he would increase the main jet. not is search of gobs of power, but more or less the technical exercise this is allowing me to go through helps me a lot in learning all these systems. also, my question is related to adding the fuel pressure regulator with the FIM chip. thanks.
repoe3 kinda answered my own questions or at least lennie did; from a previous thread: lennie said: "Your comments regarding the regulator would be consistent with my results in this area. The extra pressure of even the K12 reg is about what you need. I think they run about 3.5 bar. I have run upto about 3.9 bar with mine to get the best out of it with all the mods. This has a negative effect in other areas with too much fuel though. A chip mapped for any combination exactly however is the best option. Pitty we all don't have all the combos to test and get maps for. The FIM chip with stock fuel pressure actually removes the excess fuel from certain areas even runing the InDuct/Staintune/Cam sprocket combo as the stock map is a little too rich at these points. The BBPower chip was done without the InDuct so it would not provide enough fuel on its own to compensate for the extra on road airflow at the higher rpms and speed where it is really needed. Combining a chip and regultor though would undo the work done as Bernhard or Duane has done as their mapping is with less fuel. It is good to see you guys testing and coming up with good results and sharing these on the board." |
rob, reading the info on your site suggests to me that i would not want to do the different fuel regulator becuase it recommends disconnecting the O2 sensor. that just doesnt make sense to me. why not just unplug the O2 sensor, would that not richen it up anyways? also, when running the bike on the dyno it is not really taking air into consideration as it is getting the same volume at all RPM's. this is becoming a highly complex algebraic equation. lots and lots of factors. maybe i should just buy a custom ECU that allows direct connect and programming.
repoe3 not really consider the custom ECU just thinking online |
Repoe, you might be right but Roger might have the right answer. Or Lenie. Lennie, where are you in this discussion :) I have to say I'm very very happy with the setup as it is now. The bike pulls like a maniac, much better than my departed one and I have the cat plug still connected.
What definitely is best, whatever the setup, is a custom chip. In Holland we have a guy, Ruud Freriks in Goes (south of Holland) who did wonders on my 888 Corsa a few years back. I got a HP increase of 8 with 15 (yes, 15) in the middle of the power band. I have to say he also increased the fuel pressure with about 10% and increased the airbox volume, hence the reason I installed the K12 FPR and induct. But I am by no means an expert in this area, just fiddling around! |
Rob,
What do you mean by "and I have the cat plug still connected" ??? The plug (or wires and switch(es)) to where the plug used to be is how the correct map is selected from the bbp? Am I missing something here? roger |
Ehrr, I have the cat plug connected in the cat eliminator pipe and it is wired and connected as it was stock. The BBP map selection is done through wiring the plug in the plastic container left/front per Bernies instructions...
Am I missing something now? |
i think you mean the O2 sensor not the cat code plug that is in the box under the dash. i am really getting confused as i think some facts have blurred. i already took out the CCP, but since i run an FIM chip, that does not matter. cant really see disconnecting the O2 sensor, maybe upgrade to a new bosch unit. but it seems like what is needed is only a bit more fuel up high, not really anywhere else as it is already making over 5hp throughout the powerband.
i know it sounds like i am targeting max hp, but i am not, at least i dont think so. i am just trying to correct a fuel mixture issue that may or may not have been identified by the dyno runs. if i get more hp then great. but i love these types of discussions. really getting the gears going in everyone head. if anyone has more to share about the K fuel regulator in conjunction with a chip (but without removing the O2 sensor) i would love to hear it. of course all this talk about fuel, how about a different approach...lets say i add a pre-filter to the induct just to slow things down a bit, stick a foam filter into the nose of the induct. that kind of thing may not do anything on the dyno, but what about while riding? think think think repoe3 |
hmmm...looking back at some of the original data and recall this site and this particular comment about the power curve with the induct fitted:
http://www.moto-one.com.au/performance/r1100splaycam.html repoe3 |
Yes, you're very right. I definitely ment O2 sensor mounted in the cat or cat eliminator. Hence the name I invented (just for the fun off it) Cat Plug...
Well lets see, I was running an 02 prep(6k on the odo) with Carbon Induct, BBPower chip(stage3), SJ Filter, and Ztechnic exhaust last month and produced 94hp/71lbs on a rainy day in the upper 60's(F) with O2 sensor installed. I had a dip around 5200 rpms that really concerned me. I then installed the new Laser Race system and removed the O2 sensor at that time. Bike has much smoother roll on and I know the dip is gone but have yet to Dyno the bike, Maybe at lunch time today I can manage to get a run in. I cant expect much peak improvement, but if I managed to get rid of the dip, I will be very happy.
Thanks for the feedback Bobby.
I'd be very curious to see how that curve changes. 94HP is pretty darned decent. I have stock pipes and cans with a laser cat elim, SJ-filter, and BBP set to 3 and doubt very much that I'm even at 90. That speaks pretty well to the Ztechnik. I don't want anything much louder than I have now, so if it's reasonable, then I might have to look into it. I'm actually looking more to the weight reduction more than the power bump. Anyone ever done side by side weight comparisons of stock vs Ztechnik (I never much trust the published weights) ??? Any info appreciated. regards roger |
