Picasso Bull's Avatar
Trying to Install Cyclops LED on an '04
Has anyone here successfully replaced the stock headlamp with a Cyclops LED? That is, without major modifications.
I installed a Cyclops LED on my GS and love the improved lighting. Cylcops claimed it's 10.0 H4 bulb would be a snap to install but I've been hitting my head against the wall trying to figure it out.
Thanks, in advance, for any advice.
Sent from my Pixel 2 XL using Tapatalk
Old 01-03-2021, 03:41 PM
bobr11s
what is the problem you have ?
what type of globe do you have on your gs ?
you cannot put a h4 into a housing where there was a h7 ...
https://www.youtube.com/watch?v=--WQRsnEtX8
Ride it or it rusts .
Old 01-04-2021, 01:09 AM
2004 R1100S uses an H1 bulb for the low beam (dip) ,
and an H7 bulb for the high beam.
The regular halogen bulb that came with the bike are a safety hazard, but back then HID and LED technology
was not like today.
You will not see where you are going when riding faster than 35 MPH using the low beam halogen bulb.
2004 R1100S
Old 01-04-2021, 02:19 PM
RBMann's Avatar
Yes, but not an H4. Should be an H1 and H7. Some info here-
Anyone Using the Cyclops CIL-LED-H7 H7 4000 lumen LED Headlight bulb
You might need these for the back of the housing.
https://www.amazon.com/dp/B01N7V9P1Y/ref=cm_sw_r_cp_api_miRizbNSEGYKZ
RBMann- The road is his workshop, and his trips are opportunities to do much needed repairs. -Bill S.
* 2000 S, color-Salmon 108K+ -sold
* '17 Africa Twin-totaled* '09 F650GS twin-sold
* '83 GPZ 550-gone to a newbie * '75 CB400F-retired to AZ.
Old 01-04-2021, 04:58 PM
Registered Agitator
sgoodwin's Avatar
I'm still running the LED referred to in RB's link above with zero problems. That particular one is no longer listed but there are others with the internal ballast so you don't have to find room in the housing for it.
Old 01-05-2021, 05:55 AM
Sorry, my bike is actually an '03 BCR... my goal is to improve the lighting/visibility with as little modification as possible. Also, I should mention I'm about as mechanically inclined as a goldfish. The rep at Cyclops assured me I was buying the correct bulb but now I'm considering returning it... the improved safety may not be worth the hassle.
Thanks for all the advice so far... Keep it coming.
Old 01-05-2021, 06:41 PM
Gasteropod Rider
Meeni's Avatar
I am using a H1 Cyclop for the high for years now, it works good.
I'm still using a cheap DDM HID for the H7 low that is soldiering on years after years, no bulb color-shift yet (thing it's been some 10 years or so). Beware that DDM quality has tanked in recent years. Both ballast and bulbs have failed me on my car shortly after the warranty ends.
Old 01-05-2021, 07:33 PM
Does the bulb you took out of the motorcycle look like the bulb you are trying to install ?
Compare the metal part right below the glass.
If it looks different, it will not fit.
The Cyclops web site shows both an H4 and an H1
bulb.
Old 01-05-2021, 11:10 PM
Finally a question I have the answer to. Last year I upgraded both the low and high beam halogen bulbs with the Cyclops LED bulbs. The only modification was to replace the stock low beam rubber housing dust cover with a taller one. The stock dust cover was slightly pushed out by the LED bulb fan housing causing me some worry of overheating the LED fan. The high beam dust cover is ok.
The replacement dust covers RBMann mentioned in post #4 would probably do the trick and look like what I used. But measure yours to be sure.
Old 01-06-2021, 07:11 AM
Thanks for all the help... I think I've now got a working solution.
Old 01-15-2021, 12:37 PM
Registered Agitator
sgoodwin's Avatar
Does that align the bulb in the correct position? I would of got the correct LED with an internal ballast & skipped the cutting/silicon thing all together. Hope it works for you.
Old 01-15-2021, 01:29 PM
You guys should have warned me that the battery was harder to reach than Middle Earth!
Old 01-15-2021, 06:53 PM
Registered Agitator
sgoodwin's Avatar
Any particular reason to visit there?
Old 01-15-2021, 08:35 PM
Previous owner installed a heated seat so I wanted to rip out the wiring. Also, I installed a battery tender. PITA
Old 01-16-2021, 01:57 PM
