Original or replaced clutch slave cylinder
Hi - I’ve looked but haven’t found an answer — is there a way to know if the clutch slave cylinder is the original or an aftermarket replacement from the outside? I have a new bike and plan to drill the weep hole, but am also looking to get a sense as to whether I should plan to replace the part as well and can order it and have it ready. If it’s original, I will plan to replace it. If aftermarket, probably not on the assumption someone already has.
I assume that either way, I will need to slide out the cylinder somewhat to drill the hole, correct? If so, can I do that without disconnecting the lines? The bike just had its fluids replaced shortly before I got it and I don’t want to wait until the next interval to take care of that weep hole, and if I can avoid the extra bleeding work, why not. Thanks |
Jersey Boy In Texas
Slightly confused here. I think you are using the term "original" in the context of "this is the very same cylinder that was last touched by the factory person who installed it". But when applied in conjunction with the term "aftermarket", you are using "original" as in "Original Factory Equipment" (OEM), which are still availalble as replacements. With this dual context, your cylinder could be original (OEM), but not the one that's been in the bike since it was assembled in Berlin.
If the cylinder was replaced with an OEM part, then you need to know when it was replaced. If within the last 5 years or 15k miles, I would leave it alone, especially if the clutch fluid was changed on a regular basis (as it should be). On the other hand, if it's aftermarket and was only just installed yesterday, I would immediately remove it, crush it in a vise, and install a brand new OEM unit. I've heard nothing but bad about aftermarket slave cylinders. The cost of a replacement clutch is such that the small difference in price between an OEM (made by Magura) part and an aftermarket part is considered cheap insurance. If in doubt about if or when the cylinder was ever replaced, regardless of the current part being OEM or aftermarket, I would replace it with OEM and ride-on, confident that my slave cylinder isn't going to fail and piss fluid all over my clutch. I like the theory of a weep hole, but I question its actual effectiveness. Unless you keep your bike immaculately clean, and are always checking for drips, you still run the risk of a failed slave contaminating your clutch. I'm not that kind of person. I prefer to change my slave on a preventive basis. For me, that's 30K miles or 10 years, whichever comes first.
' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' '' ' ' ' John Filak Dallas, Texas |
Thanks. I’m still learning as this is my first r11s. I’ve gathered that the slave cylinders were a risk, one should replace them, and assumed that oem wasn’t what to replace it with (being that they go bad in the first place). I also read that they can be rebuilt or one could just get a new one, which I assumed was aftermarket. Sounds like they should be replaced but with oem and then either monitored and/or continually replaced.
I was planning to replace with this, which they refer to as aftermarket identical to oem, so not sure exactly what that is. https://www.beemerboneyard.com/21522335061n.html Thank you. |
If you are removing the slave cylinder inspect the bearing and place a small amount of thin grease in the bore and push behind the bearing to help keep it lubed. When that bearing fails it will rotate the slave cylinder piston.
87 930, |
Jersey Boy In Texas
Sure, you can take your chances with a rebuilding kit (don't know who makes one), but it'll probably be just as risky as an aftermarket one. Just to save a couple of dollars? Not a good alternative for me. I didn't get into BMWs to save money. I consider these to be throwaways. You have to decide what amount of risk you are comfortable with.
I replaced my factory original clutch slave cylinder at 40,000 miles...I used the Beemer Boneyard European aftermarket part (looked exactly like the Magura original). Not sure if there are particularly "bad" aftermarket versions out there...or what the souce might be.
In any case, I have 60,000 miles now (20,000 with the replacement slave), with no clutch problems. It does seem to pay to flush the clutch fluid every 18 months or so.
Everybody loves big twins. |
Thank you to you all for your help.
Registered Agitator
In contrast to the others my '99 has the original clutch slave so far with no problems & rarely do I change fluid & as it's never been out, there is no weep hole either. So, it's not always a problem & I'm sure I'm not the only one as forums are usually whine & cry venues. Of course, by posting this I just doomed myself. Knock on wood, spin three times & jump on one leg.
unsafe at any speed
My 2002 has 52,000 on it with original slave. I have greased the throwout bearing in it twice, when doing spline inspections/grease
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
Twisty Mt Man
When in doubt whip it out.
![]() ![]() This is how things looked when I removed the slave cylinder. I’m not sure what fluids mixed here - is it some mixture of brake fluid and transmission fluid or is it just congealed brake fluid? Can any experts advise? The goo in the cylinder shaft was hard and caked on. Clutch plates are dry so nothing made it to there. Given what you see, do I need to replace the seal in the cylinder shaft? Do I need to take things apart further and replace a seal in the transmission? It’s a R1100S so it’s tough to get to with the frame bar running right across the access area. Also, what exactly is the process to add more grease to the new slave cylinder? I feel like I’ve read to just put some high temp wheel grease into the slave cylinder bearing hole and push in with a pencil eraser but also read that I need to disassemble the slave cylinder to add more grease. Thanks! Interestingly, here’s what it looked like when I cleaned up the slave cylinder a bit. It looks like the bearing is not even up against the snap ring. ![]() Last edited by Diamicton; 07-26-2025 at 08:04 PM.. |
Jersey Boy In Texas
This is good, if true. How did you determine this? Quote:
In case I haven't mentioned it. Replace the slave cylinder. Ensure the clutch is dry. Otherwise, take the bike apart, replace the clutch and the engine rear main seal, and the gearbox input seal, and inspect the clutch splines and grease them with the BMW approved grease referenced in your Rider's Manual. If you don't have a BMW Rider's Manual, one can be downloaded for free from BMW Motorrrad website.
Thanks very much for your quick response.
I don’t think anything reached my clutch because I wasn’t having any clutch issues and everything looked dry when removing the starter and looking at the clutch. Here are some references that I’m trying to figure out how they may relate to my situation. https://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/291411-clutch-not-disengaging-advice-2.html Post 21 talks about gearbox oil mixing in. The slave cylinder definitely had a smell to it when I pulled it out. It wasn’t exactly the same as gear oil but had me wondering if some mixed in, and if so, what that means in terms of failing seals. https://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/433422-can-we-compile-definitive-clutch-slave-cylinder-fix-thread-2.html Post 38 suggests replacing seals if there is any goo. Looking at my seal, it definitely doesn’t look clean and not sure if the goo has degraded it at all. I’d rather not mess with things if I don’t need to but want to make sure I fix things right and reduce the chances of future problems while I have things apart. The following two posts talk about the bearing grease not being enough on the new slave cylinders. I bought an oem cylinder from BMW as you suggested. https://www.ukgser.com/community/threads/new-clutch-slave-cylinder-what-grease-in-the-bearing.308542/ Post 11 - add grease with a pencil eraser https://www.bmwsporttouring.com/topic/99327-clutch-slave-cylinder-longevity/ I don’t see post numbers but in the post from November people talk about adding grease but seem to say the bearing needs to come out to avoid airlock when pushing in grease and to get the grease in the right spot. Thanks again. Last edited by Diamicton; 07-27-2025 at 09:37 AM.. |
Jersey Boy In Texas
Gearbox oil cannot reach the slave cylinder without first soaking the inside of the bellhousing and clutch. Since your clutch is dry, then it cannot be gearbox oil. Maybe the previous owner of your bike is the person who thought packing the slave cavity with grease was a good idea.
