Measuring alternator output
What is the best way to measure alternator output on the S?
I'd ideally like to be able to monitor it while riding on the road, but also would like to have it available for diagnostic purposes. I think the system voltage is, and has been for awhile, a bit below spec.
And, where is the voltage regulator, and how is it replaced?
Thanks!
Old 04-11-2005, 08:58 AM
The S (and most BMWs) have a fairly generous electrical capacity (I believe it's 600W), so unless you're really adding the farkles, it's seldom a problem. But if you want to monitor the system, I'd mount an aux voltmeter such as this one:
http://www.martelmeters.com/products.php?cat=1&action=detail&id=55
It is easy to note when you're in a net discharge condition as the running battery voltage drops from a typical 14V or so down to 12.5V.
- Mark
Old 04-11-2005, 09:20 AM
Moose, looking at the manual it appears that the voltage regulator is attached to the alternator.
David G.
'07 R1200R
'99 R1100SA
'93 Ducati 900SuperSport
Old 04-11-2005, 09:51 AM
Lets see if I can post a pic for you..
David G.
'07 R1200R
'99 R1100SA
Old 04-11-2005, 10:06 AM
The best place to check charging voltage is right at the battery. Not the easiest thing to get to on the S but at least you'd know if your output is low. If it is check the tension on your alternator belt.
John B.
03 R1100S Prep(wife's), 02 Futura, 92 907ie, 89 Transalp, 87 R80/100, 82 Morini 3.5 sport, 76 R90/S, 73 R75/5
90 535im & 95 525i Touring
65, 66 Alfa Romeos
Old 04-11-2005, 11:18 AM
J. Dial's Avatar
Don't know if you guys are aware of it ot not, but the alternator on your s is a Toyota manufacture. I think this is kinda cool as brushes and bearings have to be easier to come by. Yes, the reg is enclosed in the alternator.
I put a new battery in my S last week and ran an insulated wire and connector off the positive side of the battery to under the seat. This is to facilitate winter charging and run voltmeter tests.
99 R1100S screaming yellow zonker
DT-1
650 yamaha turbo
owned two Yamaha shops
ASE Master Auto Tech. Retired vo-tech auto tech instructor
Old 04-11-2005, 11:48 AM
Thanks for the help!
It's not belt tension, but I will add the voltmeter. Since the diagram mentioned testing the alternator with the BMW diagnostics tool, I'll run by the dealer to see if they can't do a quick check.
With regards to the Toyota source comment, I read on an earlier thread that it's a Bosch alternator. Either way, if it's a standard item, it might be cheaper to purchase that way than a re-badged BMW.
Old 04-11-2005, 12:33 PM
I have the accessory socket. been using that to measure voltage.
Let us know if you find a replacement alternator form Toyota.
David G.
'07 R1200R
'99 R1100SA
Old 04-11-2005, 01:46 PM
Joe Joe is offline
Joe's Avatar
Send a message via ICQ to Joe
If your checking the Alternator by voltage measurements make sure you load the battery down by turning on all circuits to the max( high beam and heated grips on max etc. then read the voltage across the battery while running at a fast idle it should be 12-13v.
77 R100RS95 A6 Quattro
http://www.joesrepairshop.com/
Old 04-11-2005, 05:56 PM
How did you use the accessory socket to monitor voltage? did you get a BMW adaptor plug and tap the leads?
'03 Hayabusa; '99 S - Mandarin, Staintunes, InDuct, FIM chip, SJPowerfilter, Ohlins, HID; '81 FLH -93", '00 KTM 400EXC, '96 Honda XR200
Old 04-12-2005, 03:33 PM
Yup, I have an adapter plug and some extra leads that came with a battery tender.. I just clip in the leads from my digital multimeter.
David G.
'07 R1200R
'99 R1100SA
Old 04-12-2005, 07:58 PM
RBMann's Avatar
Markjenn
Your meter idea looks a lot like the one I had on my bike until the HID fried it.
http://www.lascarelectronics.com/products.cfm?STOCKNO=EMV%201200&CFID=8951843&CFTOKEN=83959491
I wonder who really makes them. Martel=$34 Lascar=$25
RB
Old 04-12-2005, 09:55 PM
