Post Weighed my 5.5" vs 5", and tire size questions
Ok, I measured them but they did have tires on them.
The 5" has a 170/60 BT010 Bridgestone and weighs in at 29.5 lbs for the package w/o brake disc.
The 5.5" has a 190/50 MTR24 Pirelli and weighs in at almost 32 lbs for the package w/o brake disc.
What size rear tires do you 5.5-inch-wheelers have on your bikes? I thought normally 180 series? This one has a 190 on it. She's WIIIIDE.
The bike is now short enough that I can sit flat footed to the ground with a slight bend in my knees, and I'm only 5'8" tall!
The flip side is that it changed the gearing enough that with a mild yank, she'll begin to lift her nose now.
Mark
San Ramon CA
Old 06-14-2001, 06:11 PM
CarlosT's Avatar
Wink
Kinda blows the Balloonitsky Effect theory eh?
Old 06-14-2001, 06:26 PM
Post
Guess it does.
They are different brands though, so unfortunately I couldnt compare same brand/different size.
Mark
San Ramon CA
Old 06-14-2001, 06:30 PM
Post
Mark
Yes the standard size for a 5.5 is 180/55/17.
Do you notice any difference in handling?
My guess is that with the back end lower, the steering would slow a bit. Won't go into the extra weight/mass, as that was discussed on earlier posts. Wondering what it does to ground clearance. Smaller diameter should decrease ground clearance, but going wider maybe gets some of it back while leaned over?
Tony
Old 06-14-2001, 09:56 PM
Send a message via ICQ to fredman
Post
I run a5.5 with a 180 tyre.I run the rear on max preload, and have a (20mm)shorter paralever strut.It made the bike turn much quicker, although a little nervous, so I managed to lower the front (about 6mm) to compenste, and it worked well.It does lift in first & second, (and third if you're hard on it and hit a bump)but handles well.I have a mate who does rider training,and they use R11s's, they run 180 on the stock rim,he says it works ok.you could easily put a 190 on the 5.5.I don't see the need for it, other than asthetics.The bike just puts the power to the ground so well, it would rather lift the front than wheelspin.
Old 06-15-2001, 04:31 AM
Rapt's Avatar
Post
Ummm... Don't you mean raised the front?
As I see it you raised the rear and that made it twitchy, lowering the front is going to make it MORE twitchy, since you're steepening the rake angle still more.
Its also worth noting that moving the fork sliders up/down doesn't change the geometry on this bike.
I am curious though as to how/why the larger tire causes the front to come up eaiser... does it have a smaller outside diametre?
[This message has been edited by Rapt (edited 06-15-2001).]
Old 06-15-2001, 05:19 AM
Post
Yes it is a shorter tire.
180/55... 55% of 180(mm?) is the height of the tire from bead to tread (something like that if I'm not stating it exactly) which equals 99
190/50... 50% of 190 equals 95 - shorter tire
170/60... equals 102 - a taller tire
Therefore we see that the aspect ratio allows you to determine roughly the variations between tire sizes.
Class dismissed.
Mark
Old 06-15-2001, 06:42 AM
turnerm's Avatar
Send a message via AIM to turnerm Send a message via Yahoo to turnerm
Post
Doesnt the extra rubber wiegh more? Just a hunch.
Im surprised a 190 fits on the bike.
I thought the 180 barely clears the rear drive.
Old 06-15-2001, 07:19 AM
Rapt's Avatar
Post
Gotcha. I knew the number was the sidewall height in percentage of width... I just hadn't bothered to actually work it through.
But it is obvious... Once you point it out...
Old 06-15-2001, 07:27 AM
CarlosT's Avatar
Cool
Class dismissed.
Mark
Tell that to Mr. Dunlop. He likes his tires BIG.
Old 06-15-2001, 08:30 AM
Post
I suspect its a combo of the wider rim and to a larger degree the bigger tire that adds to the weight difference.
The rear drive is cleared just fine on mine by the 190. Has about 3/8" clearance and shows no signs of rubbage...
I will likely go back to the 180 after this tire. I wouldve had one on it to begin with, just the p.o. had a 190 on it, so I inherited the rim that way.
Mark
San Ramon CA
Old 06-15-2001, 01:33 PM
Post
I lowered the front by shortening the rubber bushing on top of the shock, effectivly shortening the shock lenght. The did not steepen the steering-quite the opposite, because of the angle of the telelever (or front swingarm if you like).It brought the front a-arm closer to paralell with the ground.This gives it more rake, and settled the bike down.It still turns sharper than stock.I didn't move the sliders at all.
Old 06-16-2001, 04:13 AM
No Info on (t)his member
jclark's Avatar
Post
Previous in time, CarlosT caused electrons to form:
>BIG.
It's true –*my friend has 207 @180 and I Pilot Sport@180, und he has a MUCH BIGGER, um, radius, looking from the backside. Also measures that way, by about 3/4"(19.05mm)
Bigger is better, baby!
j
Old 06-16-2001, 11:02 AM
