Sidestand - some disassembly required?
Is anyone actually greasing their sidestand pivot per the manual's directions? I can't get mine apart; must be high strength thread locker in there. There's a little hole that would seem to be for lubricant but not much will go in there. Any help?
Old 07-21-2006, 09:55 AM
moosehead's Avatar
I just did mine. You need a needle tip for your grease gun( auto parts store ) . It helps if you can keep the weight off the side stand when you grease it , work the side stand up and down to work the grease around the pivot pin . 5 min. job . good luck .
Old 07-21-2006, 10:20 AM
Never heard of one but I'll check it out. Thanks Moose.
Old 07-21-2006, 10:47 AM
Barback King
Rapid Dog's Avatar
...getting the sidestand screw loose can take as much as an acetelyne torch...do the grease fitiing thing.
R11S CNC BARBACKS
Old 07-21-2006, 12:07 PM
moosehead's Avatar
http://www.doityourself.com/invt/u198754# Twinfan,check this out.
Old 07-21-2006, 03:27 PM
GS ADDICT's Avatar
yep, needle grease fitting - 1/4 a shot or until you see grease creeping out either side
If you need your Hall Sensor plate rewired - PM me.
Old 07-24-2006, 07:48 AM
