Cornering technique
In a previous post found here, I stated the following:
Just thought I'd share. Don't have lap times to prove it helps, but I know I was much faster as I got better at it. Pictures to follow as soon as I get them. |
brent1
You must be doing something right. I tried to catch you when we were on the track but couldn't keep up. You were riding strong as far as I could tell. I learn more and more each time I take one of the Code classes. Great fun too.
This is strictly for the road, but one thing I slightly differently is in identifying the turn apex (No. 5). First, I do try to anticipate the angle of the apex and the exit prior to turn-in (to set proper entry speed), but you may not be able to truly see the apex prior to turn-in, so this step may be a waste. Instead (as least where vision is limited), I try to imagine the apex and exit in my head (based on terrain, missing trees, telephone poles, etc.) rather than trying to actually "see" it.
Also, I find I can carve a much smoother arc if I don't necessarily think of the apex as a single point, but as a "sliding" apex that keeps moving forward until I can finally see the turn exit. If you look for a single apex in a limited vision situation (the road), your corner may wind up being a series of turns rather than a smooth arc.
2010 MG Griso 8V 2000 R1100S (retired) |
Underwater basketweaver
Biggest Member
yeah, they don't teach it in an MSF class, but the throttle is key to making it through a turn at speed. I use the rear tire, by way of the throttle to get through a corner as much as counter-steering.
MSF teaches that throtle is necessary in a turn primarily because as the bike leans over it begins riding on a part of the tire that has less radius than if upright.....less radius means more rpm needed to maintain speed, thus for the bike to be able to maintain constant speed and not get all discombubalated as it is leaned over one should add a bit of juice while cornering....
I sure do feel a lot more like I do now than when I first got here...... 2016 S1000XR,2001 R1100 SA: Wunderlich Seat, Staintunes, Wilbers F/R 2004 MV Agusta Brutale S 1973 BMW 2002 Touring tii, '12 LR4, 86 Mondial 3.2 QV, 02 996 Turbo |
Man it's flat out here!
Yes adding throttle though the turn works...but, if it's a blind curve and suddenly it becomes a decreasing radius curve...you just might be in real big trouble with a capital "T".
I've abandoned all this "settled chassis" business and try to be able to do anything as needed with Throttle, Clutch, Brakes, and Body "English" while in the curve. On the track you can hone your approach to a curve and find the best line, entry speed, etc...on the road there's always a surprise in store...be ready to change your body stance, line, throttle input, gradually put on the brakes, whatever it takes because it's gonna happen. Road Apples, Pea Gravel, Road Kill, "insert your line changing hazard of choice"...they all add a kind of "drama" that's the spice of riding quickly on a curvy road versus the controlled environment of a track. If I'm finding myself too fast in a curve I gently let off the throttle (engine braking effect) and gently apply rear brake first, then add front as I sense there's traction available...I don't really know how to tell you that I sense traction availability but it just takes years of experience. On the other hand, sometimes road conditions (wet, muddy, slippery) don't allow any braking and you have to just let engine braking do the job.
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD |
sorry guys, this early throttle technique was really meant for a track situation. i should have been clearer.
John, you're right about the attack angle of the turn. I should have probably mentioned someting about that. You do want to try to get in a correct attitude for turning. For example, if it's a left, you don't want to be coming into the turn from the left toward the right. Ideally, you'd be "set up" and would be sliding a little toward the left as you enter the turn in point. |
Here are a couple of photos from the day. I'll post better ones when they come in.
![]() ![]() ![]() Here are some from VIR a few weeks back. ![]() ![]() ![]() |
Hey, there's lots of green guys out there chasing a yellow one. Kawasaki the sponsor?
How was VIR? I'll be up there in a few weeks for the CLASS school.
Thanks,
Jim Moore Jax, FL '01 R1100S '07 CBR600RR |
John, Yes, the Code school runs Kawi's. I brought my own bike instead since it's cheaper that way.
Jim, VIR is nice, but I had a hard time getting used to it. Lots of blind turns and elevation change. You'll enjoy it. |
I am planning on being at Pocono to run the FUSA course on the 14th with Team Pro-Motion.
You Joisey guys should come out and play, it is a great layout.
Richard 2010 F800GS '04 R11BXA, '01 F650GS, '98 CBR600F3 track bike, '75 RE-5, '76 RE-5, '81 GS400E. Also residing in the barn my son's bikes: '89 GS500ES, Ducati Monster 620 dark |
14th huh, maybe? doubtful as it's a weekday though.
I wanna Live 'til I die!
...that whole "suspension thingy" is funny business... for the longest time I was fiddling around with the suspension on my 748 and could not get it right.... the I went to Buttonwillow for a track day and Dave Moss (the Suspension Wizzard) was there... paid him $20 and he worked the first half of the day to convert my 748 from a "Chopper" to a race bike... turns out that he adjusted the suspension in a way I would have never thought for it to work... way, way hard. Yet, the second half of the day, I was so confortable that I did not even think about it anymore and now I am so "suspension desensitized" that I hop on my Sportster, the Beemer or any of the Ducatis and just ride...
A lot of it happens between the ears, I think and the more you ride, the more it becomes second nature... I have a 20 break in riding motorcycles and clearly, the yoounger folks or the ones that never stopped have an advantage, but as I put more and more miles on my bikes, I keep getting better again... Yet - AND THAT IS THE MOST IMPORTANT PART OF IT ALL!!! - I always have fun, no matter what! Keep the rubber side down, folks... I am going riding now!
Light travels faster than sound. This is why some people appear bright until you hear them speak... https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729 2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901 |
Biggest Member
I'll be at pocono this weekend, Saturday, with Team Pro-Motion, Sunday, with Spotbike Track Time. I'll have to talk to the YetiBoss about getting the 14th off...
I may also be going to Barber in November for a two day event to finish out the year.
What day was the pictures taken at pocono.
I was at poconos august 13. I had and amazing day however by the end I pushed the bike a bit too much in one of the turns after the bus stop and I high sided the bike. As result I spent 3 days in hospital and now I am home from work for another month. I fracture my left side of my pelvis. The positive part of it is that I have a 2 month vacation from work and since I have unlimited sick days from work there is nothing that I have to be concerned. Here is a small picture of me at the track.
...ah yes, the ominous last session! Often I skip that one... long day, tired... you want to push it one more time... KaBooom...
Get better quick, eduard... hospital and sick leave afterwards are never a good combination... best wishes!
Sorry to hear Eduard, get well soon.
Although not a sure thing, I try to avoid pushing harder and just work on riding smoother which seems to make me faster..........along with a little luck so far so good.
Thread Tools | |
Rate This Thread | |
