Dbltailexit's Avatar
Key broken off, how to remove?
yes the main ignition key flush with surface. Trying to wedge it out with small tools today. Looked to remove assembly from bike but see it is a tamperproof design, but how is everyone going to change the top clamp? it appears it would need to be drilled out after removal.
any idea's would be greatly appreciated, key is not magnetic and does rotate switch. thanks ingmar d
Lotus 7 replica, 4 wheeled motorcycle.
Old 01-21-2007, 01:12 PM
wood-d's Avatar
Have you tried a shop-vac? How about some type of sticky putty?
2004 R1100S (2zars)
1957 Matchless G11
Old 01-21-2007, 01:16 PM
Skippy's Avatar
I would say make sure the ignition key is in a position that you can get it out off and then lube the whole thing then use tweesers or small pliers and keep very calm. Maybe after it's lubed it might help to tab with a nylon hammer in the neighbourhood of the ignition lock maybe this way it will move a bit upward(if your very lucky).
Meet you at the bitter end...
'09 Aprilia Scarabeo 250 i.e.
thanks wood-d and Skippy. what position is for removal, if you could describe by the clock. Currently it is at 10 oclock, 12 is in line etc. greatly appreciated. ingmar d
Old 01-21-2007, 01:26 PM
Effervescent's Avatar
IIRC, 10AM. Noon is on.
I know a guy who's key broke off in his car and he just adds the broken off bit to start and stop it. Leave the stuck half down in there. Done it for years!
I suggest Shop vac (slightly covered for more suction) before spraying lube in there. Lubing rules out "crazy glueing" a tiny, tiny metal piece as an option later...glue is a last resort IMHO.
-Eff
"Moderator: Please change the subject of this thread from"I got my first speed ticket in U.S." to "I got my second and third speed ticket in U.S. at the same time""-martincito
Old 01-21-2007, 01:56 PM
wood-d's Avatar
10 o'clock. Here's a photo. It should be pointing at the 'R'. This is if the forks are UNLOCKED. Are your locked? If so, more like 8 o'clock (OFF position in the photo)
2004 R1100S (2zars)
1957 Matchless G11
Old 01-21-2007, 01:57 PM
Moybin's Avatar
Medical foreceps are better than tweezers because they can be locked in several shut positions.
The lock tumbler is but is not tamperproof. Search the forum on locks and you will find the method to remove the tumber. From there you can just push it apart (I think).
'99 Black SA "OBSSSN" - gone but not forgotten.
Not all good technology is new, not all new technology is good.
.........Purple is Satire.........
Old 01-21-2007, 02:01 PM
thank you for the picture and info. will try glue after prying.
Success!! finally oiled slot heavily than had to hammer and depress around key on aluminum cap. was then able to using medical locking pliers and catch end of key and pull out. alum cap came off at that time and i hammer tapped it to original shape. below this is a spring loaded door that covers key slot. used small scredriver protruding from cap and held down key door as replaced cap. after many attempts was able to hold down door align cap and tap back into place. thanks guys
Old 01-21-2007, 03:33 PM
Atta boy!
-Eff
Old 01-21-2007, 05:12 PM
Skippy's Avatar
Nice one.
Old 01-22-2007, 09:05 AM
Dingo Joe's Avatar
now tell us how you managed to break it off in the first place...
Old 01-22-2007, 10:33 AM
"now tell us how you managed to break it off in the first place"
Easy How To instructions-
1)- lock up both wheels and go off into loose rock (ignore any training)
2)- somersault bike forward, shear windshield and bike continues to bounce off ground hitting seat of bike
3) best practice is to then have bike land on top of you so you absorb impact and bike is relatively unmolested. ( at least on that side). Bike was facing forward after all this.
happened in November, bike and i repairable. One piece Aerostich saved my hide.
Old 01-22-2007, 05:51 PM
a little hammer and some patience
Old 01-22-2007, 06:22 PM
Do not take too seriously
throttlemeister's Avatar
Man, that just hurts thinking about it. Glad you came out ok.
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits
BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits
http://www.sport-touring.eu | http://eurotravel.photos
Old 01-22-2007, 10:26 PM
At least you did the right thing letting the bike fall on you to protect it. Congrats on getting you key out.
04 R1100SA (Pacific Blue metalic)
99 R1100SA (black) -- Totalled
Old 01-23-2007, 07:23 AM
