Kartman's Avatar
What's Wrong????
Yesterday was the first time in 7 years that my S left me stranded. Here is what it did.
After a couple of hours of riding, it would hiccup when I hit a bump. OK, no wise guys say "then don't hit bumps". Hiccup was a nose dive for a second even when a small road seam was hit. On a smooth surface wide open thru a coupler gears, no problem. After about 15 miles of that I hit a bigger one and she quit completely never to return. I'll skip the goring details of getting it home and go right to what I found, so far.
1. Engine will spin but no sparkies and no fuel pump singing when key is turned to on.
2. Checked all fuses and Motronic relay and fuel pump relay. OK
3. All connectors in front wiring boxes are secure.
4. Carefully checked sidestand switch. OK
5. Checked main cable & connector going into ECU. Just visible under fuel tank with fairings off. Seems tight and no obvious pinched or broken wires.
So, What's wrong??? Could my Motronic ECU have totally crashed.
Being an electronic engineer I naturally suspect the ECU. In my job life I have experienced printed circuit board cracks from vibration that can ultimately develope into an open circuit & functional failure. This has all the symptoms of that kinda nitemare.
Could be a fuel pump failure, but why no spark. Too much coincidence to have a coil & fuel pump failure at same time. Unless the brain (ECU) is not telling them to do their thing.
Any similar experiences or direction would be appreciated before I have to load her up on the trailer down to SCC BMW in Watsonville to do a ECU scan. $$$$
99 R1100S, Z06 Vette, KLX250S,Jeep Wrangler, Cayenne
Old 03-05-2007, 10:52 PM
Do not take too seriously
throttlemeister's Avatar
My guess: cable going into the ignition switch, seems to be a week spot.
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits
BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits
http://www.sport-touring.eu | http://eurotravel.photos
Old 03-06-2007, 01:23 AM
Biggest Member
gigantic's Avatar
Send a message via AIM to gigantic Send a message via Yahoo to gigantic
+1
Old 03-06-2007, 03:09 AM
Kill switch, or the wires to the kill switch? Also, maybe the hall effect sensor, but I think you would still have a fuel pump whine with a bad HES.
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 03-06-2007, 03:10 AM
Kartman's Avatar
Exclamation
Didn't think of ignition switch.
I'll be all over the ignition switch first thing this morning. Should still be sensitive to movement or vibration, hopefully.
Thanks guys.
Old 03-06-2007, 07:57 AM
Living on borrowed time!
JonyRR's Avatar
let's start with the simplest thing(s) first. What kind of battery voltage do you have.
What you're looking for, of course, is 13.5VDC at the terminals. Start at the beginning here but for sure the ignition switch wiring bundle being kinked and eventually causing an open there is a good guess. The thin-gauge wire on these things suffere very little stress before pulling an edsel.
Better a has-been than a wanna-be
'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'.
Old 03-06-2007, 09:05 AM
John Lyon's Avatar
With the front wheel back and forth movement over time, sometimes the wires or connections have broken. I "loosened" the wires around my switch some time ago (gave it more slack) to help prevent it.
2010 MG Griso 8V
2000 R1100S (retired)
Old 03-06-2007, 08:06 PM
Kartman's Avatar
Smile
Mystery solved. Loose connector on Motronic ECU module.
Old 03-06-2007, 09:24 PM
Seventies Man's Avatar
Maybe a silly question : where is the ECU? Its not the same as the TPS is it? -Martin
now gone 2004 r1100sa
multi branded shaft and chain type
GS owner 50 hp highly manueverable
Old 03-07-2007, 05:31 AM
It's the metal box underneath the gastank, in front of the battery.
Old 03-07-2007, 06:35 AM
roger albert's Avatar
whereas the tps is the black plastic little box on left the side of your left throttlebody.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 03-07-2007, 01:34 PM
Man it's flat out here!
R111S's Avatar
Always be sure to Twist the Throttle between min and max a few times before cranking, after the Motronic Unit has been disconnected from power.
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD
Old 03-07-2007, 07:21 PM
