R1150 Input spline lube in 1 hour????!
Its been a while since I was here as the Adventure Rider site is more GS oriented but I felt I had to share this with all.
Being due for another spline lube in 4000km and not wanting to rip the bike apart before next winter I went down to the shop this am and removed the starter to see if there could possibly be an easier way. A trip to our local druggist (who is a hot rod nut ) and some explaining I left with an handfull of syringes and needles. Some time on the lathe and bench followed and the pictures say the rest. YES, it is possible to fiddle the needle assembly into the input shaft spline trough. I put the bike in 6th, clamped the clutch lever in and marked the starting point on the clutch hub with a dot of paint. The tool tip takes a little patience to work down the spline and a constant pressure on the syringe slowly releases the Starburegs. I stopped squeezing once I saw the grease coming back out of the spline. The length of the needle is just over .250" so I figure if the contact surface is approx. .750" I wouldn't be putting too much. Centrifugal force should do the distributing. It took no time at all and the job was done, starter back in and a quick road test. Upon return I removed the starter again and looked for evidence of excess grease slinging around - NONE! I estimate I injected .5 ml to do the the job. The job is so easy to do I think I will do every 20000 km or one a year as a PM. I welcome everyones opinions on this idea including whether I should even take the bike apart this winter. FYI the pictures are as follows 1) tool in use 2) tool tip shown on old clutch and input shaft for clarity 3) tool 4) grease that was extruded from the tip (very fine bead) easy to meter out. Needle O.D. is .027" Attached Images
If you need your Hall Sensor plate rewired - PM me. |
Good job. Nice pics. Good explanation.
Mark |
Uh....who me?
This looks like a great idea. The local druggist had a bent tipped needle? The process wouldn't handle the cleaning part but would sure provide fresh lubricant. Wonder how the build-up of lube affect things after you've done this several times....where does it go?
Just wondering out loud.....great idea with the starter removal to at least check part of the splines. I'm not familiar with the term "Starburegs". This is the recommended grease?
Bob Hancock '20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss "There are times when good words are to be left unsaid out of esteem for silence." St. Benedict |
Looks like a great idea, what did you do with the lathe, I assume you worked on the needle. How did you bend without kinking?
Jim
down to jap bikes that run and a dead Norton |
Dont taunt happy fun ball
Nice!
Yes, how the needle was handled and and what the lathe was used for would both be very nice to know. Great idea, and thanks for sh aring.
Bob, yes, starburegs is the lube. Not sure if that's still the name, but it's still the same red bmw lube. And yes, buildup could be an issue over time, but surely this could be done at least every other time (maybe every third) drastically cutting the effort. Or just whenever the rear main seals fails and it has to be pulled apart anyway ![]() And no, I don't think I'd bother to disassemble. Looked pretty clean in the pix, and you'e lubed it, so enjoy the free time. Bob, will you be making these for us? At least the lathework?
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works www.ororcycle.com CMRA EXPERT #841 Various Formula 5, 6 & 7 championships 2006-2012 A3, Navigator, |
Uh....who me?
Doing some other projects for folks for the R12 series. Making my own to see if it works then making a few others. 19th century technology is slow...wish I had CNC. I got an idea for changing the rear wheel from Ivan Messina that I did one of but it took me 4 hours and he can get them done CNC in 10 minutes, so no production work planned. WORK! Did I like...say....WORK?
Hey BoB PM with your phone #
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel ![]() 1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, heads ported and polished Bigger valves installed intake and exhaust! SJ power filter, motoyoyo clamps , HID
Answers.......
Starburegs is the BMW grease Needle easily bent over a 1/8" dia rod (blunt the end first for safety) Lathework was the threaded brass adaptor from the syringe to the brass tube Very easy to clean up just pump solvent thru. Syringe is cheaply replaced at less than 1$ Syringe & needle is a 'Precisionglide' 1ml 27G 1/2
Banned
Great concepts. Thanks a lot.
Is it necessary (or wise) to unhitch the electric cable from the battery first or just work carefully with the cable at the starter motor end? With the Airheads, people would attach a toothbrush to a stick of wood but the tranny had to be backed off enough to get the toothbrush in. A brush is a somewhat better kind of applicator because it applies the grease to the hills and valleys. Having said that, while you need to get the grease reasonably distributed to each spline and groove but not perfectly distributed because the motion of the clutch disk spreads the grease some. And even if one spline goes dry, the greased ones will shoulder the load until they are dry and start to wear. Design of the clutch, flywheel, etc, on the Airheads made the clutch pretty hard to get grease on from slightly over-greasing the splines. Same on R1100S? At the risk of a flame war, is Honda Moly still the most revered grease? Last edited by Peter Parts; 03-22-2007 at 09:45 AM.. |
It never was. Dries out too much.
If you need your Hall Sensor plate rewired - PM me. Last edited by GS ADDICT; 03-22-2007 at 10:45 AM.. |
Man it's flat out here!
Thanks for the excellent idea and posting your text and pics GS ADDICT...I'll be attempting this on my R1100S very soon. I'll be sure to post my results as well.
I always used VW CV-Joint Grease (Moly) on my Airheads Clutch Splines...I plan to use the same on my R1100S.
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD |
gday folks,
If you purchase a "drawing up needle" it has a blunt end, and a larger bore. they are used for "drawing up drugs", ( im medically trained) a newbie question, how often should this splines be lubed? thanks in advance Phil, Australia
Phil, Australia ![]() BMW 2001 R1100s BMW 2003 R1200CL |
Hi ploz58,
I don't have my Manual handy right now but I'm planning on doing my first lube at 40K Miles later next week. I'll post my findings afterwards. Others here have done it sooner and later. If you abuse your clutch you may want to do it sooner than later.
Bump!
I would like to here some more feedback on this process. My bike now has 57k miles and I don't think the input splines have ever been lubed. I would like to do the same process on my k75s if possible.
Ryan '23 R1250RS, '99 R1100S, '98 CB750, '88 K75S, '74 CB360, '70 CL450 Café Project, '81 Yamaha 250, '05 S2000, '08 RDX Turbo Last edited by R1100S2000; 01-15-2012 at 03:52 PM.. |
Never tried it on a K bike.
Spline Lube
I know spline lube is part of maintenance on older BMWs (pre 80s but not exact) but not mentioned as required in my '02 RT and '04 S bikes.
Do most of my maintenance, but will take the bikes in from time to time. No service manager has ever ask me about greasing the spline. Do like the needles, but is this really necessary or recommended? Thank you, Nathan |
Just do a subject search on ADV Riders or the BMWMOA
subject line splineshaft failure, input shaft failure, spline lube. You will find lots on the subject, BMW does not acknowledge the problem........ if they did they would be on the hook for all the repairs.
