Tranny Drain Plug Tool?
What do you guys use to remove the tranny drain plug? The manual has a drawing of a special tool. Does anyone have one or something similar that I can rent?
Thanks,
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 03-31-2007, 08:25 AM
Jim,
I bought mine from Sears. You only use one of them but they come in a pack of three.
http://www.sears.com/sr/javasr/product.do?cat=Mechanics+Tools&pid=00943303000&vertical=TOOL&subcat=Socket+Accessories&BV_UseBVCookie=Yes
Old 03-31-2007, 08:52 AM
BMW Atlanta's Avatar
Send a message via AIM to BMW Atlanta Send a message via Yahoo to BMW Atlanta
it's a 14 mm allen. If you can find a good bolt with a 14mm head and then weld a bolt onto it that might work for you. Otherwise 14mm hex stock cut down will allow you to use a 14mm wrench to remove.
Bobby
BMW Ducati & Husqvarna of Atlanta
06 HP2 SM, Akra Ti, RapidBike3,
BobP63's Avatar
I've used the same Craftsman set that jduke provided a link for, works fine just make sure you have the wrench fully engaged on the square drive.
Old 03-31-2007, 04:11 PM
Uh....who me?
Bob Hancock's Avatar
I use this one
Bob Hancock
'20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss
"There are times when good words are to be left unsaid out of esteem for silence." St. Benedict
Old 03-31-2007, 05:05 PM
Uh....who me?
Don't be fooled by the 17...it's a 14 as Bobby says. I got it from a Mercedes tool site. Works well but still can't use a torque wrench.
Bob Hancock
Old 03-31-2007, 05:07 PM
850dunstall's Avatar
handy dandy cheap tool
i went to the bolt supply place and bought a 3/8" coupling nut.
coupling nuts are 1-3/4" long and are used to connect thread rod ends. 3/8" is 9/16" across the flats, trim it and file and grind the faces lightly till it goes into the drain plug
i got lucky, just put a 9/16" wrench on the piece sticking out and gave it a good tug and its loose.
my daughter absconded with the camera so i can't give you a picture right now
claus
IBA, 04r1100s, 11f800st, 74norton, 05f650gs
auf Adlers Fluegeln getragen...
Old 03-31-2007, 06:37 PM
Take a 14mm headed bolt that has at least 1" of thread. Thread two nuts of the right thread onto the bolt. Tighten (jam) them together as tight as possible. Stick the head of the bolt in the drain plug and turn the upper nut to unscrew the drain plug.
Old 03-31-2007, 07:14 PM
Got it, thanks. Man, you guys are smart!
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 04-01-2007, 02:09 AM
or, just buy a 14 mm allen wrench, and chop a 2" length off the long end.
"Wow I'm an idiot, thanks bikerfish!"
Harleys are like opinions, every a-hole's got one!
2001 R11S "lite", with a few mods.
2009 F800GS. has a better saddle. and other stuff. (sold)
2016 R12GSW 3Black. wow.
Old 04-01-2007, 12:28 PM
