stock header question
Sunday, 9:30 a.m., cup of coffee in hand, when a question re-hit me. I'm in the process of getting my BCP headers and Z-Tek up pipe ceramic coated (no plug for the company), and on removal, I wondered what function the cross-over pipe served in the exhaust design of the stock bike. Just curious.
Uh....who me?
That's a very good question....the easy answer to which I would normally have spouted off about. However, given recent things we've seen, none of them explain in my mind why we see such diversity. Take the R1200S for instance. Stock header has cross-over. Replacement Remus does not. The R12S HP we saw race at LeMans has two. So what does this mean? Is this just fine tuning for the application? Is one method wrong? I don't know.
Bob Hancock '20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss "There are times when good words are to be left unsaid out of esteem for silence." St. Benedict |
Bob certainly knows more about this than me;but, I've been told that it's a sudo two into one adaptation that allows for improved evacuation of the exhaust plus reduced back pressure because the exhaust gas has the use of both pipes to get sucked out and therefore a boost in HP. Only a dino could prove/disprove this assumption. I've always heard that two into one systems produce more HP. The crossover does simplify the pluming problem and gives balance to the look of the boxer engine.
![]() I found this blurb on the website Hi Pro motorcycles have one pipe because the entire exhaust system is tuned to the upper power band. Bike engines have to be small and light and powerful, and the faster you can spin the crank the more explosions per second you can get, thus the more power, so designers can only meet the power demands on a small engine by spinning them faster and designing everything accordingly. At these higher RPM's the exhaust system can scavenge if the system is tuned for it, in short not only is there no back pressure there's actually a negative pressure there in part of the exhaust cycle that literally sucks the exhaust right out. Maybe this makes a case for not messing with the factory stuff unless you install the entire tuned after market system. I admit that I'm not the expert here but it does make me think. Noise does not= more power. It's just that NOISE. Last edited by Guest24; 04-29-2007 at 03:01 PM.. |
Dismembered
More than just a simple cross-over pipe, if you look inside there is a restrictor, which presumably tunes the pipe to improve evacuation, although I'd expect that it's effective only at certain rpm's. When thinking about racing exhaust designs it's useful to remember that those bikes spend most of their time running flat out and so it might not matter if exhaust scavaging is not efficient at lower rpm's where us street riders spend a lot of time. If you really want to speed the exhaust on out & away then install the SJ exhaust inserts. They really, really work and yes that's an endorsement.
farkled '04 R1100S SOLD! 2012 Ducati Multistrada Pikes Peak (#072) "It is difficult to get the news from poems, yet men die miserably every day from lack of what is found there" WC Williams Last edited by GotRoad?; 04-29-2007 at 05:36 PM.. |
I would guess the restrictor (haven't looked personally) would set up a venturi effect to assist in the evacuation at high revs much the same as the SJ inserts.
The SJBMW exhaust inserts are already inside the headers. The ceramic coating from there to the can should also help exhaust scavenging significantly, not to mention great looks on the headers. I also used Ultralux teflon coating inside my SJBMW power filter from the nozzle back thru the whole plastic housing. Got some from a boating buddy on Lake Texoma, he uses the Ultralux to reduce drag on water on his V-drive racing boat. Definite increase in intake noise, performance, who knows?
Do a search on the subject and you'll find some comments have been made in the past. I know Nate Kern clipped the cross-over the other year, on his 1100S, and welded up the hole and got a touch more power on the top end. Some have stated that the restrictor in the 1100S cross-over was designed to add peak HP. Opening up the restrictor a bit gives more mid-range grunt. This past winter I hogged out the cross-over restrictor to 7/16th and I feel a difference.
As for the twin cross-overs on the 1200S HP motor, that is just one of many details we'd all like to get a better explaination of.
Trex |
Let me get the coated headers on, will shoot back a pic. For the air system, the PTFE was a clear coating, it just looks shiny and is very, very slippery. He said the stuff is $190 per gallon, a tad more than enough for the bottom of a 21' fiberglass hull. Part of the price of being competitive, for him anyway.
Wait, a slick coating makes more noise on an air system now?
I can't keep up with today's science.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works www.ororcycle.com CMRA EXPERT #841 Various Formula 5, 6 & 7 championships 2006-2012 A3, Navigator, |
No Info on (t)his member
Never said or implied the "slick coating" created noise. The noise comes from air passing through the SJBMW "cold air" induct/airbox system into the engine intake with less restriction and more velocity. A FTPE (Teflon) surface is also electrically and chemically inert. Air passes more efficiently across or through a smooth surface, even moreso where there is no static electricy generated to attract dust particles. Less friction. Ever wonder why they put Teflon on skillets? Or coat industrial pipes with Teflon to increase flow efficiency? Or why turbos and blowers seem to be such a popular way to increase horsepower?
All I know is that if on stroke 4 when your engine doesn't have to waste energy pushing against the out route that unwasted power goes to the rear wheel. Friction free suction is a new arena. We've now moved from the rear end to the front end. |
Actually, where that stuff works really well is on the nose of my bike and the Cee Bailey. The bugs come off with nothing more than couple of swipes with a wet towel, even grasshopper guts that seem to turn into an organic cement.
I removed the crossover tube at @15K made the exhaust note a little more raspy, I now have 43k on the bike with no problems!
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel ![]() 1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, heads ported and polished Bigger valves installed intake and exhaust! SJ power filter, motoyoyo clamps , HID
