Motorradfahrer
Eisernkreuz's Avatar
Send a message via AIM to Eisernkreuz
Accessorizing: Power sockets, alternators, etc.
Hey guys,
Forgive me if this is a repost, the search function returned nada on this particular question..
I have a 99 R1100S and while it has heated grips and some other options, it doesn't appear to have an auxiliary power socket. I'd really like to add a heated vest or some sort of heating device to boost cold-weather comfort, but I'm not sure how I would go about doing that, especially since I'm not sure which alternator I have, the standard 600W or the 700W option.
1) Where is the accessory socket supposed to be? I checked around the front, by the gauges where the fuses are. Couldn't see it. I also checked around under the seat. Nothing there either. Could it just not have it?
2) How do I find out which alternator I have? Are they marked?
I need to get a warmer jacket regardless (current suit is perforated), but I graduate from UC Davis this December, so who knows where Christmas break will take me?! I'd rather have it and not need it than need it and not have it haha. Thanks in advance.
-Miran
99 R1100SA
Old 08-02-2007, 12:57 AM
The socket is located below the seat on the left hand side near the exhaust, part number for the kit is 71607671607, this will mate to a spare connector under the seat on the right hand side if it was fitted.
1993 R100GS PD
2003 R1150R Edition 80
2003 R1100S BCR
Wanted - 1939 R50 TT or RS54 Rennsport
Old 08-02-2007, 03:38 AM
I ran a Gerbing jacket most of last winter. It nominally draws 77 watts/6.4 amps. Most usage was on a KLR with a +-200 watt alternator. My commute is only ten minutes, never needed to put the battery on a charger. The S should have plenty of juice.
Jim
down to jap bikes that run and a dead Norton
Old 08-02-2007, 05:20 AM
unimog's Avatar
Photo of stock location below.
I added a SAE type connector up by the gauges to power my GPS & phone. I tapped off the LH fuel block (up stream) for that.
'04 BMW R1100S BCR
'01 Audi TT RS
gone but not forgotten:
'87 911 Carrera '59 356 Coupe
'66 912 Speedster '99 996 Ducati
Old 08-02-2007, 08:33 AM
Jeff Williams's Avatar
Nice panners
Riding, releases my mind from the tyranny of petty things. Thats why i ride.
2003 Boxer cup Rep
2113 Multistrada S Touring
95 R100RT Classic, a keeper
Old 08-02-2007, 03:19 PM
unimog's Avatar
Originally Posted by Jeff Williams View Post
Nice panners
Thanks.... actually a million thanks to LIGHTFIGHTER on this board. He hooked me up with the color matched lids and seat.
'04 BMW R1100S BCR
'01 Audi TT RS
Old 08-02-2007, 05:49 PM
Motorradfahrer
I checked, there's nothing there. Then again, my bike's completely missing that evap canister (it wasn't relocated, it's literally missing) so who knows what else has been taken out by the original owner
Thanks for the help guys. I guess I'll have to just get a warm jacket and some chemical heating packs
-Miran
99 R1100SA
Old 08-02-2007, 10:42 PM
unimog's Avatar
Miran,
It is worth adding the power socket, even if you don't plan on running heated gear, etc. It is a great location to plug in a trickle charger. Don't worry about not having the cannister, it is a pretty common mod to remove it.
See it here on Pelican Link to canisterectomy
or over at IBMWR http://www.ibmwr.org/r-tech/oilheads/cannister_horn.shtml
I'd also add the battery jumper post on the starter Retrofitting Starter Cover Jumper Post , since the battery is a very tough access.
'04 BMW R1100S BCR
'01 Audi TT RS
Old 08-02-2007, 11:39 PM
Ride Far - Ride Fast
Dan Alexander's Avatar
I've got one of the accessory sockets for sale .. go the the 'R11s Parts For Sale" forum by the forum jump button below.
74 R90S, 77 R100RS, 85 K100RS, 2-87 K100RS
99 R11S
2002 Blue and White GS ... the prettiest
2008 KTM 950 Super Enduro long distance gravel road and general hooligan bike.
Now an R11GS and a 650 Dakar
Old 08-03-2007, 07:17 AM
Edministrator
Steve Carlton's Avatar
Miran- the socket wasn't standard equipment. I think the lower-output alternators came with the '99s that didn't have ABS. Either way, you should be fine using an outlet.
Good post? Leave a tip!
O - $1
O - $2
O - $3
Old 08-03-2007, 07:28 AM
Motorradfahrer
My bike has ABS (and heated grips). I'll check that stuff out. Thanks guys, you rock!
-Miran
99 R1100SA
Old 08-04-2007, 12:46 AM
DCRider
I'm planning to add the powerlet accessory port to my new to me '02 BxC Prep, anyone have a photo of where the OEM wiring harness mates to the spare connector mentioned above, or can you describe the connector?
'02 BxCup Prep and '03 R1150R
Old 01-23-2023, 06:19 PM
Been Nowhere Done Nothing
Swamper's Avatar
It's under the seat by the diagnostic plug.
05 R1100S BCR, 04 R1150R
16 S1000XR, 24 S1000RR,
21 Ducati 950S
Old 01-24-2023, 07:40 AM
DCRider
Yep found it, thx
Old 02-01-2023, 06:25 PM
