Beemercobby
Beemercobby's Avatar
Question Throttle body sync using twinmax
Hi everybody,
Ive no doubt that this has been covered many times on this forum but does anyone have a definitive step by step guide on how to sync TB's on a 2003 1100S using a Twinmax.
Ive read Jon Diaz's ' Throttle syncing for R1100's' who uses a Carbtune. It seems pretty straight forward but I'm thinking of buying a Twinmax which I believe is more accurate.
Thanks, Beemercobby.
Old 12-15-2007, 12:35 PM
I wanna Live 'til I die!
signit98's Avatar
Send a message via AIM to signit98
http://www.ibmwr.org/r-tech/oilheads/index.shtml
you'll find everything you need and then some... have fun!
Light travels faster than sound. This is why some people appear bright until you hear them speak...
https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729
2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901
Old 12-15-2007, 12:53 PM
Beemercobby
Thanks signit98,
Your right, theres plenty of info and then some on that link. Can I ask, is it safe to assume that the high rev adjustment takes place on the right side throttle cable for all model years. Is the cable set up different on my 2002 model compared to a 98 or a 99?
Thanks, Beemercobby
Old 12-15-2007, 01:31 PM
signit98's Avatar
...ought to be the same.
I do idle with the brass screw and then 3000 rpm and 4000 rpm with the cable... works like a charme!
Old 12-15-2007, 01:53 PM
tm1100s's Avatar
I have a carbtune and it's not very accurate. Metal rods (dry) in plastic tubes, on springs. Never used a twinmax.
But for about 4 bucks, a clear plastic tube, in a loop with some ATF inside, each end hooked to the vacuum ports works better and faster than anything else.
tm
(R12, R11, R1) + 00 then S, S, /7
Old 12-15-2007, 02:14 PM
roger albert's Avatar
I have both. The twinmax is much much better (more consistent)
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 12-15-2007, 04:04 PM
Check this out. Way better thana twinmax, and practically free.
http://www.rightspin.com/motorcycles/LowCostMano/mano.html
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 12-16-2007, 02:36 AM
Originally Posted by Beemercobby View Post
Thanks signit98,
Thanks, Beemercobby
They are all the same,i only ever ajust the right side,have never touched the left side in 8 years!!!,with a TwinMax
Old 12-16-2007, 04:52 AM
The liquid manometer are pretty good, but a bit bulky to store and use.
Also useless for real tests under load, which is what really matters -- Not how your bike runs in neutral on the centerstand.
Real tuning requires real tools. (but the liquid units ARE OK and certainly better than nothing)
www.ororcycle.com
CMRA EXPERT #841
A3, Navigator,
Old 12-16-2007, 08:15 AM
unsafe at any speed
wswartzwel's Avatar
I have used mercury carb stix for 30 years... too old to change.
Bill Swartzwelder
Old 12-16-2007, 02:44 PM
Beemercobby
Thanks for your replies everyone. I've decided to go down the Twinmax route. I'll probably order one in the new year which is when I'll be back on the forum with the ' HELP I've screwed up my tuning' heading.
Thanks, Mal.
Old 12-17-2007, 12:26 AM
Anyone still use a COLORTune?
aka Rev Z-Man -- RIP www.bmwforums.net
- 1950s Ford 9N Tractor
- 2021 Subaru Outback Onyx XT
- Drummer for 12 Days Straight
Old 12-17-2007, 07:28 PM
RBMann's Avatar
I still have one but it will not help with sync.
RB
Old 12-17-2007, 08:15 PM
Whoa! Diaz' name on Pelican? The world is shrinking. . .
COLORTUNE??? Wow, I'd almost forgotten about that. I'll have to go home and see if I can find mine. Now that was an example of "toy money". Nice to look at, but that was about it.
Old 12-18-2007, 05:51 AM
