Brake rotors
I mic'd mine last night and they are below spec.
Any suggestions on replacements?
Stick with stock? Alternatives?
Old 01-11-2008, 09:21 AM
MoDog's Avatar
Get those groovy wavy wavy rotors; that's what I'm going to do. Do a search; I can't remember where all they can be found, but quite a few of the guys on the board have bought them.
Orange '08 KTM 990 Adventure for fun in the rough stuff
Patientlty awaiting an R-bike sport tourer devoid of servos and EWS
Old 01-11-2008, 10:46 AM
Do not take too seriously
throttlemeister's Avatar
And I don't like em, but I am a loner I guess. I removed them and went back to stock rotors. Their behavior did not fit my riding style and the discs wear too fast.
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits
BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits
http://www.sport-touring.eu | http://eurotravel.photos
Old 01-11-2008, 12:17 PM
time wasting tosser
Highlander179's Avatar
define "behavior" please?
Old 01-11-2008, 12:28 PM
Little to no initial bite, more force needed to create same amount of slowing down, the hotter they get, the better they work.
Now these are all things that would work great on the track, but I don't ride there. I want high initial bite, little force needed and consistent behavior wether they are hot or cold.
They are also very soft. Using my favorite brake pads, which do not give any measurable wear on the stock rotors over 6,000 miles (no suprise), they wore down the Braking wave discs by .25mm over that distance. That's ¼ of the total life of the discs in 6k miles. Using the Braking pads reduced the wear rate, but behavior stayed the same.
I'll stick with stock discs and my fav pads for braking the way I like it.
Old 01-11-2008, 12:41 PM
Thats why you pay a lot more.........and get the Galfers instead of the Braking Power units. The Galfers are harder, better made, cost more, are thinner, and stop very fast. They especially help control in wet conditions. Take care. I will be switching to Galfers on the new HP Sport...............when, and if, it ever gets here.
Old 01-11-2008, 05:03 PM
Really. If that were the case, it would be all over the board. And it is not, as I think I have read every thread dealing with Galfer and Braking discs. The only reason people prefer Galfer over Braking is because they are 4.5mm instead of 5mm. Personnally, I don't like manufacturers that void warranty on product A if you do not also use product B, which is what Galfer does.
Anyway, the only reason I went with Braking is not because some perceived BS performance increase, but because OE rotors are so damn expensive. There is a reason why the top brake manufacturer Brembo refuses to make wave rotors while everybody else does and that's because there is no performance advantage. In fact, the reduced disc area only causes the discs to get hotter and more force is needed to get the same stopping power. These things are for looks or cheap OE replacement only, and having seen my bike with both I personally prefer the OE look.
Old 01-12-2008, 12:55 AM
What the man said,here in the Uk 'Brakeing' have a deal with Blunderlich so we have to pay more!! i've a rear Brakeing disc(bought before the deal) it's worn badly,a friend with Galfer has not had that problem.
The only thing,Galfer ain't dearer,well not over here they not.
Old 01-12-2008, 04:15 AM
Uh....who me?
Bob Hancock's Avatar
Jerry, I've always been quite satisfied with the stockers. Loved the stock brakes on my last R11S and feel the same way about ones on my current bike. I also note that a racer friend had them replaced with stock rotors after his sponsor put the wavy ones on his race bike, and for the same reasons that tm said, as I recall. I really think this is one of those items where the factory does better than the aftermarket. fwiw.
Bob Hancock
'20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss
"There are times when good words are to be left unsaid out of esteem for silence." St. Benedict
Old 01-12-2008, 04:50 AM
EZ-RIDER's Avatar
I find them to grab better then the stockers
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel
1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, heads ported and polished Bigger valves installed intake and exhaust! SJ power filter, motoyoyo clamps , HID
Old 01-12-2008, 05:09 AM
Kristian,CO's Avatar
Thanks for your feedback TM, probably saved me some money.
Kristian
2001 R1100S
Old 01-12-2008, 05:23 AM
EZ-RIDER's Avatar
Bs!!!
Old 01-12-2008, 05:25 AM
my braking wavy wotors have been berry, berry good to me.
one of the stock front rotors is now part of a wall clock.
the other one lives under a wooden planter box so the water drains out the hole at the bottom.
'04 R1100s. I changed a couple o' things.
Old 01-12-2008, 05:34 AM
roger albert's Avatar
I'm with Brad.
My braking Rotors have been GREAT, with no signs of increased wear. Could be a bit, but not much at all. Initial bite is better, and max braking MUCH better. Short of the shocks, it's the best upgrade I've made on the bike. I rode an S with the Galfers too. Also nice. Felt about the same as my Braking setup. Both are a big improvement. Made a bigger difference than the braided lines for sure. I'd never go back. Two customers (both actually on RSs) were thrilled as well.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 01-12-2008, 06:34 AM
Man it's flat out here!
R111S's Avatar
I got an EBC Pro-Lite OEM replacement Disc/Pads for the Front Brake of my '94 BMW R100GS/PD and was very pleased with the improved performance and the price was reasonable too. But that was my only experience with a non-OEM Brake Disc.
You can download their 316 page PDF Catalog from the EBC Website: http://www.ebcbrakes.com/motorcycle.html
Here's the EBC PNs for a '96/00 BMW R1100S:
Front Rotor Left: MD687LS
Front Rotor Right: MD687RS
Rear Rotor: MD653
The later R1100S's have larger Brake Rotors on the front so the PNs are different. There's also specific P/Ns for Integral ABS.
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD
Old 01-12-2008, 07:23 AM
unsafe at any speed
wswartzwel's Avatar
I used the EBC prolites on my Superhawk... They stopped great, (I could lock up and smoke the front tire with 1 finger) but were prone to surface rust ( not a concern for me.. but might not be liked by others)after being ridden hard and put up wet.
Bill Swartzwelder
Old 01-12-2008, 07:55 AM
for those of you with worn out rotors- what kind of mileage are you seeing when they go belly up?
"Wow I'm an idiot, thanks bikerfish!"
Harleys are like opinions, every a-hole's got one!
2001 R11S "lite", with a few mods.
2009 F800GS. has a better saddle. and other stuff. (sold)
2016 R12GSW 3Black. wow.
Old 01-12-2008, 07:56 AM
My stockers are worn, and it has 72,000km on the clock (45k miles)
Old 01-12-2008, 11:11 AM
R111S's Avatar
I would guess that this mileage may vary widely because of differing factors like landscape, city/rural, style, load, etc.
My front rotors look fine at 49K Miles w/4.5mm thickness and using EBC "HH" Pads. My riding is flat landscape, mostly rural, use lots of engine braking, and mostly solo w/o bags.
Here are the Rotor specs for my '99:
Old 01-12-2008, 03:44 PM
Deans BMW's Avatar
Chris at San Jose BMW uses stock rotors and pads on all of their race bikes, he finds that they work best overall.
Dean O
Copperhill,Tn
Founder, San Jose BMW
www.motorcyclistcafe.com
www.sjbmwracing.com
Old 01-12-2008, 03:50 PM
