Flatbutt1's Avatar
Creaky forks
Guys, when picking the bike up off of the side stand I get a creaking from the fork tubes that I can correlate with the action of the top tubes settling into the bottom legs. There aren't any springs in there that I am aware of (nor any pictured on the fiche)so could this just be a matter of lubing the sliders?
Whatcha think?
big blue tricycle
stare down the darkness and watch it fade
Old 04-18-2008, 09:11 AM
I wanna Live 'til I die!
signit98's Avatar
Send a message via AIM to signit98
Ah, you're just gettin old, Tom!
Light travels faster than sound. This is why some people appear bright until you hear them speak...
https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729
2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901
Old 04-18-2008, 09:31 AM
Snark and Soda
Steve Carlton's Avatar
Put the earplugs in sooner.
Two EVs and a BRZ
Old 04-18-2008, 09:52 AM
Talk Less, Say More
ckcarr's Avatar
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
You better lube your slider.
cRaIg CaRr
2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer.
Old 04-18-2008, 09:54 AM
Flatbutt1's Avatar
signit: make that getting oldER!
Steve: what?
ck: the ladies luv me so much they make their own lube!!!!
big blue tricycle
Old 04-18-2008, 11:41 AM
signit98's Avatar
LOL... funny, very funny!... I am still convinced that you hear your knees creaking!
Old 04-18-2008, 12:44 PM
Talk Less, Say More
ckcarr's Avatar
"If these forks are creakin', don't bother peek'n..."
cRaIg CaRr
Old 04-18-2008, 01:17 PM
Send a message via Yahoo to Doyle Whiting
Apply your brakes and see if noise goes away.
Old 04-18-2008, 02:29 PM
I had the same thing with the old RS, I attributed it to the ball joint, or A frame, if memory serves me correctly, don't remember what I did, but it was no more than lubing something.
Richard 2010 F800GS '04 R11BXA, '01 F650GS, '98 CBR600F3 track bike, '75 RE-5, '76 RE-5, '81 GS400E.
Also residing in the barn my son's bikes:
'89 GS500ES, Ducati Monster 620 dark
Old 04-18-2008, 03:32 PM
motoyoyo's Avatar
Could be your front shock mount bushings. I have seen the lower ones get pretty trashed on some bikes. Take the lower shock bolt out and apply some grease to the lower bushing and bolt and see if that stops the creaking. Ball joints would be the next thing to look at if that doesn't get it.
Scott
'98 R1100S - Triple Clamps, 10mm Shortened Telelever
2013 KTM 990 SMT, 2008 KTM 990 SDR
Old 04-18-2008, 04:21 PM
BINGO, that was it, just needed a little rattle of the cobwebs, my bushing was fine just had to R&R the bolt and spray a little chain lube on it.....Whats chain lube???????...wait this is a BMW forum. OK, spray a little of your favorite lube on it, and no the "natural stuff" is water soluble and will not hold up well, white lithium grease will work
Old 04-18-2008, 04:57 PM
Has the bike ever had a front-end impact? I worked on (can't say 'fixed') a bike a few years ago with this problem. Several people had previously worked on it to resolve this issue, and once I found the creaking to be in the fork legs I pulled the tubes out. Bent tubes, got new ones. Put it back together; better but I didn't notice that the problem had not entirely gone away.
Bike comes back two years later, leaking fork seals. I notice the creaking again. Tubes still OK but they would bind at the bottom of fork travel. I replace the sliders. Problem totally gone. Both tubes AND sliders were bent in the initial incident.
In this case the problem was noticeable when on the centerstand, front wheel in the air, turning the handlebars. Others had diagnosed it as bad upper bearing, bent frame, all kinds of stuff. Of course the S won't sit with the wheel in the air quite so easily, but you might want to jack it up and see if you notice this when you turn the forks from side to side.
Anton Largiader
Charlottesville, VA
Old 04-20-2008, 01:33 PM
Anton said "...the problem was noticeable when on the centerstand, front wheel in the air, turning the handlebars..." Just what did you notice? No, I'm not messing with you Anton.
Old 04-20-2008, 01:55 PM
Flatbutt1's Avatar
I've lubed the ball joint(hehheh its 420) and the shock mount. Its quieter now but I'll know better aftr tomoorows commutte.
big blue tricycle
Old 04-20-2008, 02:26 PM
Thinking about it again, I don't think it'll apply to the S, but on the GS/RT/R the top clamp movement is not orthogonal to the fork legs, so when you turn the forks you get some fork extension and retraction. In the case I mentioned, this was enough to demonstrate the creaking.
The S and RS have top ball joints and conventional fork top clamps, so you probably won't get that effect. I would drop the fork tube out of the top clamp and slide it up and down in the slider to see if it was sticking. If it is, I doubt it would simply be a lubrication issue. Would be nice (and a lot cheaper) though.
Anton Largiader
Charlottesville, VA
Old 04-21-2008, 02:43 AM
Thanks Anton. I'm now wondering what weight the HP2 Sport will the sprung for out of the factory.
Old 04-21-2008, 06:25 AM
Flatbutt1's Avatar
OK, I took some time and really got under the covers. Its definitely coming from the forks when they compress, not the ball joint.
So is there a rebuild procedure?
big blue tricycle
Old 05-08-2008, 04:59 PM
Flatbutt1's Avatar
bump
big blue tricycle
Old 05-09-2008, 11:16 AM
I would start by unclamping the top and sliding each tube down into its slider. If one of them's binding, you will need to do more than just replace seals.
Anton Largiader
Charlottesville, VA
Old 05-09-2008, 12:02 PM
Flatbutt1's Avatar
Thanks Anton, so aside from seals no rebuild is possible. Any thoughts on what might cause the binding?
big blue tricycle
Old 05-09-2008, 02:11 PM
