Running voltage?
When I rev my bike, the charging voltage only goes to about 13.7 volts. I have read that it should be about 13.9-14.2.
Is this true?
Is there a concern?
Brushes?
Okay?
Old 05-26-2008, 03:01 PM
Not. I would think you're in the margin of error for your voltmeter. I bougt a Kuriackan (sp) voltmeter to check the current draw when running my Gerbing jacket. It proved easier to read than a Fluke strapped to the tankbag.
Jim
down to jap bikes that run and a dead Norton
Old 05-26-2008, 03:11 PM
13.7 is not uncommon, it may be more of an indicator of battery health, than charging system.
Richard 2010 F800GS '04 R11BXA, '01 F650GS, '98 CBR600F3 track bike, '75 RE-5, '76 RE-5, '81 GS400E.
Also residing in the barn my son's bikes:
'89 GS500ES, Ducati Monster 620 dark
Old 05-26-2008, 05:08 PM
Living on borrowed time!
JonyRR's Avatar
that's not enough.
something's wrong.
I always want to see 14.5VDC at about 5K rpm regardless of what it is.
I'll bet dollars to donuts it's the battery...if the bat is >2 years old, do an AMP draw test (go to autozone).
Better a has-been than a wanna-be
'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'.
Old 05-26-2008, 06:43 PM
Jony
I would consider that on the high end of the scale but I appreciate the AZ plug. It has been one of my better stock picks. I would not expect my local counterman to interpret the results of a load test on a motorcycle battery, perhaps you can expect to have more faith in yours.
Jim
Old 05-26-2008, 07:10 PM
JonyRR's Avatar
well, drag out a manual for virtually any vehicle with a 12 volt negative ground charging system and I'd bet it says 14.5VDC as a correct charge level.
but of course, free advice is worth what you pay for it.
make up your own mind.
Old 05-26-2008, 08:40 PM
squall_line's Avatar
Given that this is the same member that has had the ABS failure lights alternating after startup, but then clearing after a 5 mile ride and re-start, I'm going to bet that the battery health is the culprit of the low voltage being seen while running.
I know that the battery is a PITA to get to, but I have to ask myself why, after being told to replace a battery, someone would spend more time chasing gremlins that don't exist than it would have taken to just replace the battery by now.
J.J.
Mandarin / Black '99 R11S-A - black YoYo clamps, black wheels, black front forks.
Former bikes: '93 R100R, '93 K1100LT, '02 R1150RT, '03 K1200GT, '97 F650ST
Old 05-27-2008, 09:39 AM
I agree that my two concerns (ABS lights and questionable charging voltage) may be related. I hope so to be sure. I ordered a Odyssey PC680 battery and it should be here by the end of the week. I'll update once installed on both topics. I have my fingers crossed!
Old 05-28-2008, 12:43 PM
roger albert's Avatar
Those are virtually always related.
The regulators on these vary more than you might think, but in general, 14.5 is a pretty high expectation. If that's the metric, at least half of all oilheads don't charge properly. 14 +/- a quarter covers most of them.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 05-28-2008, 01:16 PM
Thumbs up
Okay, I put the Odyssey PC680 in Saturday. I have had it out a few times now. The charging voltage seems better. Now it runs at about 13.90 - 13.95 volts (just under 14).
No ABS lights, and I think that it runs smoother at idle. (Am I imagining this?)
Old 06-02-2008, 05:22 AM
That will certainly keep you going but still seems low. I take it you are measuring voltage at the battery with a digital voltmeter with the bike revving 3-4k? An AGM battery likes to see 14.2v & your Odyssey prefers closer to 14.5v for optimum battery health. My old Airheads are set up so I get 14v at 3k & above so I'm sure your Oilhead can do better then 13.9v. Have you cleaned all the connectors, checked/cleaned the grounds & checked belt tension/condition?
John B.
03 R1100S Prep(wife's), 02 Futura, 92 907ie, 89 Transalp, 87 R80/100, 82 Morini 3.5 sport, 76 R90/S, 73 R75/5
90 535im & 95 525i Touring
65, 66 Alfa Romeos
Old 06-02-2008, 05:56 AM
I cleaned the battery connections, but not any of the others. I say the battery ground, it looked okay with no corrosion, so I didn't take apart.
Trouble?
Old 06-02-2008, 11:32 AM
