A Real S-Hole
zustation's Avatar
Exhaust Soot
Just wondering what the latest thoughts are on exhaust soot on the R11S? I've got considerable amounts of soot that poops out of the exhaust, and leaves black marks all over the license plate. Not a big deal as it washes right off, but seems a bit strange to me.
I found a thread here that said this was probably normal, but what causes it? Is the bike running rich, or is this because of the way the bike still burns oil?
This bike has 22000KM and has burned through about a half pint of oil in the last 500Km or so. Do you still get soot once the bike has broken in a little more and stops with oil burning?
Old 08-27-2008, 09:01 AM
Uh....who me?
Bob Hancock's Avatar
That does sound a bit rich. Has the bike been modified any with aftermarket exhaust or chip? How do your plugs look?
Bob Hancock
'20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss
"There are times when good words are to be left unsaid out of esteem for silence." St. Benedict
Old 08-27-2008, 11:50 AM
mrbroek's Avatar
Me too!
My bike has 4,000 miles on it and it does the same thing, although I only get soot from the left side, onto the left third of the license plate. Plugs look okay, as far as I can tell. Bike is not modified at all. I sure would like to know what causes it.
MrBroek
2004 R1100S
Old 08-27-2008, 12:37 PM
Motomuffin's Avatar
New here, don't mind me...
Mine's an '01 with 57K miles on it. It's always done this (OK can't say always but I've owned it since 28K miles and it's done it since then), out the port-side pipe more than the starboard (port-side comes straight(er) outta the manifold). I always chalked it up to the oil it uses: smoke --> soot. Has an aftermarket FI chip and certainly runs rich; goes through about 1/2 a quart of oil between changes.
I clean the pipes off regularly but leave the soot on my plate (stickin' it to the man!). ;-)
Old 08-27-2008, 01:04 PM
You certainlt don't wany an aircooled boxer to run lean. Do you get out on the road occassionally and run it in the 6-7k rev area? If not you need to. If you have a two into one system the left is always going to be the primary exhaust can. When the revs get up there the right takes the up the slack.
Old 08-27-2008, 01:49 PM
Man it's flat out here!
R111S's Avatar
Mine makes soot too but not much on hot days and more so on colder days. There must be a temperature sensor that richens the mixture when it's cold.
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD
Old 08-27-2008, 06:27 PM
Uh....who me?
Not for the stock R11S system, which for some reason flows the right side (as seen from the back) first...then the left at higher rpm.
Bob Hancock
Old 08-27-2008, 06:56 PM
A Real S-Hole
zustation's Avatar
Definitely no aftermarket exhaust, and no chip that I know of, but I'm the second owner so not 100% sure.
Mine does the same thing as mrbroek's bike, lots of soot on the left third, but I assumed that's just because the pipe to that side is a straighter run to the cat.
Spoke to the dealer yesterday about it, they say this is pretty normal, and their advice was to get friendly with the rev-limiter. Sounds like a fun plan to me.
Old 08-28-2008, 10:31 AM
Seems like I saw a stock set of can cut open on one of these forums and one side looked like the path of least resistance then the other as exhaust volume increased just like you described Bob. That's above my fluid mechanics level.
Old 08-28-2008, 12:04 PM
Living on borrowed time!
JonyRR's Avatar
Perhaps it needs a new 02 sensor.
they ARE a service item, y'know...
I just put my 3rd set in my '94 530I cage.
NAPA has a generic bosch 4-wire OEM replacement for about 1/2 the price of the OEM BMW part number.
Better a has-been than a wanna-be
'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'.
Old 08-28-2008, 12:16 PM
