LinkBack Thread Tools Rating: Thread Rating: 2 votes, 1.00 average.
Underwater basketweaver
SergioK's Avatar
Send a message via AIM to SergioK Send a message via Yahoo to SergioK
Need to expand the tool collection - front brake caliper spreader
What do you guys use, besides a screwdriver, to push the pistons back into the cylinders on the front brake calipers when changing out the brake pads? I'd like a proper tool for the job. Searched the board and found nada. Suggestions?
'05 R12GS
'08 HP2 Sport
'16 GT4
Old 09-15-2008, 08:40 PM
Living on borrowed time!
JonyRR's Avatar
It's a screwdriver by any other name
I can probably rustle you up a surplus AH64 Apache main wheel brake caliper piston separation tool, NSN 1209877-1223-5556-8367-43645, but it'd still be a screwdriver for all intents and purposes.
Have Fun at Yosemite.
Better a has-been than a wanna-be
'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'.
Old 09-15-2008, 09:02 PM
I wanna Live 'til I die!
signit98's Avatar
Send a message via AIM to signit98
Screw driver... but carefully so
Light travels faster than sound. This is why some people appear bright until you hear them speak...
https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729
2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901
Old 09-15-2008, 09:07 PM
SergioK's Avatar
How did I know you hooligans were gonna suggest a screwdriver?
'05 R12GS
'08 HP2 Sport
'16 GT4
Old 09-15-2008, 10:05 PM
Send a message via AIM to Bigred455
channel locks
-George Hill
'12 GSA, '00 Mandarin S, '09 HP2S, '99 Naked S, '03 Yam YZ250F, '91 Suz Dr350, '01 Yellow/Black S - Dead
Old 09-15-2008, 10:31 PM
Gone Bush
twodear's Avatar
For the front calipers, remove the bolts to one side at a time and twist it before removing it from the disk. Twisting will cause the pistons to retract far enough for the caliper to be reinstalled with the new pads in place. Do only one at a time as twisting one with the other already off will just cause the pistons to extend.
The rear is easier since there is only one caliper.
If enough is enough and more is better then too much should be just about right.
Member of AAAA (Association Against Acronym Abuse)
'22 H-D 'F' outfit, '46 Indian Chief outfit, a couple of early Honda Benlys, "BUBba" - R1150GS Adventure
Old 09-16-2008, 01:56 AM
Take a drift pin and grind it into a oval. put it between the brake pads and twist.
Old 09-16-2008, 06:09 AM
squall_line's Avatar
I did it the way TwoDear did, but I had to crack open the M/C on the handlebar to be able to get any appreciable retraction from the pistons.
Thankfully, I didn't lose TOO much paint when I did that...
J.J.
Mandarin / Black '99 R11S-A - black YoYo clamps, black wheels, black front forks.
Former bikes: '93 R100R, '93 K1100LT, '02 R1150RT, '03 K1200GT, '97 F650ST
Old 09-16-2008, 06:27 AM
SergioK's Avatar
So no one uses any special tool other than a screwdriver?
'05 R12GS
'08 HP2 Sport
'16 GT4
Old 09-16-2008, 07:59 AM
signit98's Avatar
yes, I do... a wooden wedge, it's softer on the brake pads and you can leave it in... in the winter you'll have something to burn if in a crunch!
Works just as well as a screw driver and I have had instances where the pads got damaged with the driver...
Old 09-16-2008, 08:04 AM
Well, I use the BMW tool. An '02 should have the EVO caliper, where you can take the pads out the top, right? BMW's newer caliper tool (with the iABS tools) is awesome. Pull out the pads, insert the tool, crank it open. The whole kit (2 of these plus some spacers and stuff) is about $500. BMW part 83 30 0 402 161
Previous version is tool# 34 1 500, old spreader for ABS2 Brembo caliper, nothing special. I don't have one. I rock the caliper on the disk.
New one is # 34 1 531 new spreader for EVO caliper, plus the -532 locating clip. $293 + $15. Two of each come in the kit, so just buy the kit.
Anton Largiader
Charlottesville, VA
Old 09-16-2008, 10:13 AM
Barback King
Rapid Dog's Avatar
...you can get a reverse flat blade plier if you look around, works better than a screwdriver...
here
R11S CNC BARBACKS
Old 09-16-2008, 12:00 PM
SergioK's Avatar
This is more of what I'm looking for...
http://www.zdmak.com/wbstore/main.asp?action=PROD&PROD=MK-BRK-J&CTMP=1&LowCt=0
'05 R12GS
'08 HP2 Sport
'16 GT4
Old 09-16-2008, 01:57 PM
signit98's Avatar
...by the time you are done re-setting one caliper with that tool, I have both calipers back on the bike, new pads and all... you sure you are not an engineer?
Old 09-16-2008, 02:57 PM
i agree Ralf. When did compressing a piston on the caliper get to be such a anal piece of work.
Old 09-16-2008, 04:39 PM
